SDA DIY Interconnect Cable - 2 Male pins type
le91163
Hello,
I'm restoring a pair of Polk SDA's that came with a poorly made SDA interconnect cable. I believe this is the 1st generation SDA because it has the 2 male connectors and a female connector underneath which I believe is only there for alignment purposes only, but I could be wrong.
I've searched ebay for several months and can't find this type of configuration connector so I'm looking for a DIY option. I'm good at crimping wires and such but I'm not in a position where I feel comfortable replacing or upgrading the connectors on the back of the speakers so a suitable interconnect cable can be used.
If there's a recommendation for the female part of the connector then i think I can get it to work just fine.
Thanks in advance.
Thanks in advance.
Answers
Nope you are out of luck there. Your best bet would be to change to speakon connections. Yes you are correct that those were only used a very short time before they went with the Blade/blade socket. The two male pins should be the only two carring signal, the bottom female socket should have been only for support.
