Bass and Treble Settings
MikeT66
MikeT66 Posts: 21
edited May 2004 in Speakers
What do you guys recommend setting the bass and treble settings at?? Should I just leave them set flat at 0 for each. Any help you can provide is appreciated.:)
Mike T
Onkyo TX-SR501 (Receiver)
Polk R50 (Fronts)
Polk R20 (Rear Surround)
Polk CSi3 (Center)
KLH Sub
65in Mitsubishi HDTV
Post edited by MikeT66 on
  • organ
    organ Posts: 4,969
    edited May 2004
    Leave both at 0 or bypass the controls if possible. If you prefer a different sound, play around with the settings to find the one you like best.
    Maurice
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2004
    Flat 0! I used to have my treble cranked up, but I gradually turned it down over the last few months. If you are used to having it cranked, you may have to ween yourself like I did. Now it hurts my ears if I set it to where I used to.
    Regards,
    PolkThug
  • madmax
    madmax Posts: 12,434
    edited May 2004
    Start at 0. If you don't like it after a few days change it. It is my opinion that it is almost always best to change the room and/or equipment around to achieve the correct tonal balance for the majority of your recordings rather than doing it electrically. None of my stuff has tone controls and after a little re-arangement I don't need any. I would never go more than +/- 2 on them at the most if I had them. If you do then you have something else wrong and even though it helps a little it is hurting you somewhere else.
    madmax
    Vinyl, the final frontier...
    F1nut Posts: 52,198
    edited May 2004
    Flat!
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2004
    Flat!
    If...
    Ron loves a film = don't even rent.
  • madmax
    edited May 2004
    Just one thing to remember here. We are talking about systems that are basically flat at 0 right? I mean the important thing is that the material is presented flat, not what the controls are set at...
    madmax
  • warviper
    warviper Posts: 585
    edited May 2004
    I have mine set to flat on the treble but I am using the bass boost. It your music I would set it to the level that you like it best.
    Different speakers have different abilities and in the end its your gear and your ear.
    Wish I was a polkologist then I could call my self Dr.warviper.
    F1nut Posts: 52,198
    edited May 2004
    Actually, I don't have any tone controls, so flat is the only option. It seems to me that when one moves into seperates they just don't come with tone controls, if that tells you something......eh?
  • gidrah
    gidrah Posts: 3,049
    edited May 2004
    Set it at whatever sounds good to you. Start at 0 and go from there. It depends alot on your room and personal tastes. One of my rigs doesn't have tone controls and if it did I'd set them flat or bypass them, except for "loudness" at lower volumes. The other rig needs a little adjustment. It's in a much larger room with hardwood floors
    A buddy of mine really cranks up both the bass and treble, but he's got a rather moderate system (but tons of music - all formats) and seldom listens to acoustic music. He likes that sparkle and oomph.
    I know that flat is "the way the artist intended" and is more pure, but they have done their part and made their money. If flat works for you great, if not tweak it.
    Make it Funky! :)
  • kberg
    kberg Posts: 974
    edited May 2004
    I agree with gidrah. Although flat can be fine for most, I think that even after calibration, it also depends on the source material. For example, I personally like the opening credits/sound of Top Gun with bass at +2 and treble at +6. Other source material is best running flat (for me). Who's right? THE LISTENER - ALWAYS!
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    With both my HS and my HT systems comprised of separates and without tone controls says something about my stance on this subject. I'm just not for running the signal through an extra set of signal degrading circuits. (And it's far more important to me to keep the signal as clean as poss. where it concerns my 2chHS.) However, I can see a limited role for them... if used wisely, controls can try to help make up for a "sonically challenged" listening room. If faced with such a problem I'd much rather work on the room to make it more audio friendly first...
  • gidrah
    gidrah Posts: 3,049
    edited May 2004
    :eek: Welcome back Bob. :)
    Make it Funky! :)
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    It has been a while hasn't it ?
    Now, if I can only figure out where I've been...
  • jcaut
    jcaut Posts: 1,849
    edited May 2004
    I'll second the welcome back, Bob!
    Jason
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    I figured it was time to see what's up, see who's still here from the old days, (a lot of guys by the looks!) see some new names (a lot of those too!) and find out what people are talking about these days.
    I see that there seems to be some strong knowledgeable additions to the group.... that's good, real good. On the other hand without having to look real hard, seeing that somethings never change, if you get my drift... not so good.
  • frankerchino
    Buenas tardes, soy nuevo con una barra Polk Max AX sr y me gustaría que me dijeran cómo tienen los settings de bass, treble, sowrrounds, height etc... Ya sé que es cuestión de cada uno pero habrá una que coincidan tod@s ...
    Gracias por adelantado y un cordial saludo 🙏
  • skrol
    skrol Posts: 3,483
    That's because you have to buy a separate equalizer.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,198
    Stan is playing funny man tonight.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited October 2023
    “Good afternoon, I am new with a Polk Max AX sr bar and I would like you to tell me how you have the settings for bass, treble, surrounds, height etc... I know it is a matter for each individual but there will be one that everyone agrees on. ...
    Thanks in advance and best regards”
    Bienvenido a Club Polk!
    Espero que esta traducción tenga sentido 😊
    Pruebe primero con "plano".
    Luego, realice pequeños cambios en la configuración de graves y agudos. Al final, lo que realmente importa es lo que “te suena” mejor.
    ¡Disfrutar! Tony
    *all connected w/Premiere ICs
  • daddyjt
    daddyjt Posts: 3,198
    skrol wrote: »
    I’m betting Jesse has something like this ;-)
    ― Aleksandr Solzhenitsyn
    pitdogg2 Posts: 27,642
    Pretty dancing lights.
    F1nut Posts: 52,198
    daddyjt wrote: »
    skrol wrote: »
    You lose...lol
  • jdjohn
    jdjohn Posts: 3,416
    Wow...it only took 19 years for guys to come up with these 'zingers' :D
    Experienced audiophiles know that all you need is a LOUDNESS button to get the job done ;)
    edited October 2023
    Well unless you have a good ol' Yamaha product, then you have a variable loudness knob.....
    I always liked those.
    mhardy6647 Posts: 35,421
    daddyjt wrote: »
    skrol wrote: »
    I... I have one.
    :blush:
    it is in the basement.
    it's also wrapped up in packing paper and taped shut.
    but..
    it is... there.
  • daddyjt
    When I was 15, I would have had one if I could have afforded it - hands down. I thought that was the coolest thing when I was a kid…
    Bass and treble...
    edited October 2023
    ahem. on topic.
    21st century audiophile-approved "tone control"*
    ________________
    * Plus, there're always cables. ;)B):#:blush:
  • skrol
    skrol Posts: 3,483
    Proper equalizer setting…
    Stan
    Main 2ch:
    HT:
    Other stuff:
