Change things up or stick with what I got
nooshinjohn
I am looking at a dCS Puccini SACD and U-Clock. The combination would also serve as a DAC, allowing me to stream my stored media, and Qubos. This would end up replacing my Sim audio 380d DSD.
The Simaudio is much newer than the Puccini, but the dCS features the ring-DAC.
Any thoughts guys?
Any thoughts guys?
I've no experience with any of what you listed, but I suppose the general rule of thumb would be can you afford it? Is it a worthy upgrade? If the ring DAC is a significant upgrade you can justify, why the flip not?
Can you currently stream your stored media? If not, and the ring DAC is a genuine upgrade, I'd do it if I was in your shoes.My gear:- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
