L200 internal wiring question
Hello
I recently bought a pair of used L200 speakers. The original owner changed the internal wiring for single speaker wire use by combining the positive lead for the tweeter & woofer to one terminal, and both negative leads to the other.
I want to change the wiring back to it's original state, but I don't know which leads are for the tweeter/woofer.
Just unhook them then plug an amp up to each set to see what plays- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Leave it that way.Political Correctness'.........defined
President of Club Polk -
Leave it that way.
But I'm wanting to sell them, and put them back in their original state -
Did they change the wiring inside? OR did they just combine both to a single pair of posts? If the latter you should be able to take the woofer out to see the color of the wire to the woofer and take the other two off to move to the top posts.
It should be a simple process.
