Cat scratch fever
sbb2112
I am kinda sick about this and have to decide which way to remedy this. My wife got a new kitten and well, it likes to climb anything it can. I was sitting reading and look over and see her about a foot from the top of the grill on my SRS's. Good thing she is fast as it wouldn't have ended well. I remove the grill and all the drivers on the outer side have damage to the surrounds. I had replaced them when you could still get the drivers from polk. They are the B/B 1st gen. My question to everyone is, which would be the best way to fix this? I can glue the tears with something, maybe have them fixed, or get the midwest versions. Midwest says they are close to the originals? Anyone have a comparison? or suggestion?
Main System
Marantz AV8802A PrePro
Marantz MM7025 Amp rear surrounds
McIntosh MC7205 Amp center, ceiling and mid surrounds
McIntosh MC300 Amp front mains
Oppo 203 Bluray
Polk SDA-SRS with VR3 monastery crossovers
Polk FX1000 Mid surrounds
Klipsch RP-440C Center channel
Klipsch RP-15M Rear surrounds
SVS prime elevation ceiling surrounds
Rythmik F15HP sub
Samsung 8500 curved screen 65" LED 4K
Mac Mini Server
Office System
Musical Fidelity M6s dac/preamp
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server
Wang Dang Sweet Poontang 🐱"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I recommend picking this up.
https://www.amazon.com/101-Uses-Dead-Simon-Bond/dp/0517545160/ref=sr_1_1?crid=2QTABP47NCXJ2&keywords=what+to+do+with+a+dead+cat&qid=1696365233&sprefix=what+to+do+with+a+dead+cat,aps,153&sr=8-1Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
My suggestion would be a lead aspirin. As for the MW's if you're talking about the surrounds, you can use shoe goo or I think F1 uses Allenes.Gustard X26 Pro DAC
Aleen's Tacky glue is not meant for rubber, so do not use that. You need a rubber repair product.
Other than that, get the MWxxxx model number off the back of the drivers and start shopping eBay.Political Correctness'.........defined
President of Club Polk -
I'm pretty sure the first SDA-SRS was all MW6503.
I fixed our cat when it was young by trimming the nail to the nub and keeping them that way. The second thing was wrapping my speakers top to bottom front and sides with heavy cardboard that Velcro'd to the back. With time the lil'bas'erd grew out of his wanting to be on top of everything. I still until he died kept his nails trimmed to no sharp points.
I also remember someone who used rubber inner tube patches and the glue they use to good effect, might be worth a try.
Hope this helps. -
Get the kitten a lots of climbing toys, with carpet and scratch pads. The more toys they have the better it is for your speakers. We have 4 cats and none of them have ever climbed my speakers, because we have too many more fun toys they can climb. -
Gyah, that sucks.
Get rid of the kitten. Burlap sack, rocks and a John Boat. You can get all off Craigslist, easy. Buy from different people so that it doesn't look suspicious and to avoid obvious entrapment stings. (Watching true crime shows pays off.) If you think your wife may object, make sure the sack is large enough for both of them. I've done this several times. You'll likely meet other cool guys and their wives and kittens out at the lake.I disabled signatures. -
Gyah, that sucks.
I like your cut, brother.....
I’ve been lucky, the cats have always been deterred from dorking with my speakers....
I plan for the future. - F1Nut -
I feel like I have the only cat that doesn't scratch and destroy stuff or chew on stuff.
Hope this helps.
What type of glue do you recommend to glue the little patches of inner tube to kitty's feet?
They tend to lick things on themselves. Food grade glue I reckon?
Super glue that sucker to the ceiling!!
Patches go on the back side of the rubber surround if that is where the tear is. -
Milk the circumstance for all it’s worth. State your case for replacement Polk Legend L800s. 😂
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
When I had cats, I always let them hear and feel the raw power of the 1.2TL’s at AC/DC concert levelsevery theme the got within 10 feet of them… they learned quick to stay away.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Unfortunately, my cat is also a music lover. This seemed to work pretty well.
Current system: SDA-SRS, Carver Crimson 275 amp, 10 Octave LP-1R preamp
Previous system: SDA-1, Carver M-1.5t amp, Adcom GFP-1A preamp
I listen better than I used to, but I don't hear as well. -
Great to be animal free.
Got busy with other projects and finally got time to think about this. I found this
and it fixed the surrounds and stays really flexible. I put some on the gaskets to keep them in place too. Used a toothpick and smoothed over. Still thinking about MW speaker 6503 replacements after the cat issue is worked out. The bug zapper idea was a good one
Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server -
Introduce your cat to one of these and it will most likely leave your speakers alone. You may want to put a little catnip on/around the post initially and encourage the the post to be a play zone. We had two 20-pounders and they were obsessed with the post and never touched the polks:
https://www.purrfectpost.com/ -
If you have need for 6503's I can help. I only need two spares for 2B's having thinned my POLK collection. I have a similar problem with a cat. But he's a good cat.
Pictures/Photos Library.photoslibrary/resources/derivatives/A/A810EBFA-4295-4715-83B0-846FCD9EF23E_1_105_c.jpeg
/Users/ /Pictures/Photos Library.photoslibrary/resources/derivatives/B/B8A1C2C2-18EA-4528-8B5A-A7AFA23B88D7_1_105_c.jpeg/Users/ji[img]https://us.v-[/img] -
I have been busy and haven’t been here in a while. I will look the repairs over and if no new damage I would like to replace them.Main System
Oppo 203 Bluray
Rythmik F15HP sub
Mac Mini Server
Office System
Oppo 103D Bluray
Polk SDA-SRS 2
Parasound HCA-1500A
Polk PSW 650 sub
Microrendu
Roku Ultra
Mac Mini Server
