Polk ES90
Looks like Polk finally released a matching height module for the Signature Elite series...
https://www.polkaudio.com/en-ca/product/home-speakers/height-modules/signature-elite-es90/300849.html
They look quite nice. If anyone ends up getting these I'd be curious to know how they perform. Seems long overdue though but it's cool that you could now build an Atmos equipped theatre fully out of the ES series.
My gear:
  • TCL 75QM7K TV
  • Onyko TX-NR656 AVR
  • RT3000p Fronts
  • CS1000p Center
  • RT35 Side Surrounds
  • RT35 Rear Surrounds
  • Emlyn
    Emlyn Posts: 4,703
    Cool. I like they put a rubber base on that model to help isolate them from the speaker underneath. The Reserve version doesn't have that.
  • Emlyn wrote: »
    Definitely a nice touch. It's really cool how it sits on the curve of the speaker itself too.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    VR3 Posts: 29,427
    Just curious as I'm not knee deep in the home theater space anymore. I thought all height modules that were certified by Dolby and such had to follow certain specifications and parameters
  • VR3 wrote: »
    I believe this is the case in order to obtain Dolby certification. It's just frequency response that I know of that's a specification though.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • Unfortunate that it won't fit on my ES50s...
  • sm1th5
    sm1th5 Posts: 18
    The best thing is the 5.25 inch woofer.
