Help identifying tweeters on what I believe to be Polk Model 11 or RTA-11s
I don't know what these tweeters are on what I believe to be Polk Model 11's or RTA-11's. I bought them about 15 years ago and have poked around on here and haven't seen any tweeters like them. Thank you.gfox7xvs01l3.jpg
Answers
  • I think it is an sl-1000 after googling some more images, but I would like some confirmation
    pitdogg2 Posts: 26,915
    SL1000 is correct.
    F1nut Posts: 51,655
    Your binding post nuts are reversed. Red goes on the left.
  • Thank you for your confirmation of the tweeter model. As far as the binding posts, I didn't mess with them, I'm hoping the PO simply took the nuts off and can easily replace them by switching them back. I have no idea why someone would do that. Great catch!! I would have just gone with the colors so thank you!!
  • ChrisD06
    ChrisD06 Posts: 912
    Is there any harm that can actually be done by having them reversed on both, seeming as they'd still be in phase with each other?
    Like, are there any polar components Polk used in the crossovers which could get damaged, or no?
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    BAD SOUND They're playing out of phase.
    Go home tonight and switch yours for the entire weekend and listen to them out of phase....report back.
  • boston1450
    boston1450 Posts: 7,758
    edited August 2023
    Igotstoknow the Monitor 11 is a great speaker. I hope you enjoy them. I had a few different Monitor 10's & I decided to try the Monitor 11 & make my own decisions & the 11's did well. I got rid of the Monitor 10's & I hooked the 11's to a Yamaha CR2040. I later opened them up. Removed the base (spiked the cabinets) Cleaned up the cabinets. Sealed the cabinets. Did all the woofer magnets to prevent shifting. Made sure everything was in correctly (with help from Forum members-thank you). Had lots of fun learning my speakers... There is a fair amount of info archived on the forum. Hit the search button & enjoy some great threads...I've noticed Google has some info but most is deleted over time... Keep us posted what you think & enjoy your vintage Polks
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    msg Posts: 10,450
    @boston1450 - maaan, you got me good. I was reading your post, and kept waiting for the all important question, because you started your post with Igotstoknow.
    I didn't realize at first that it's the OP's name. #&$*.
  • boston1450
    No. My wife calls me igotsasmallone but I don't listen to her
    Randy-Maine
    by David WMG
    edited August 2023
    Killin me brah
  • ChrisD06
    ChrisD06 Posts: 912
    Done. I can't tell the difference?
    I swapped the cables around on both of my M5JR and I cannot tell the difference... maybe a minor difference but I'm not sure.
    I then tried having only one out of phase and yeah I could very obviously tell. Voices which are supposed to be in the center of the stage are extremely localizable to both speakers.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • bcwsrt
    bcwsrt Posts: 2,361
    The weekend’s not over yet!
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
    edited August 2023
    Out of phase, when a big bass note hits instead of the driver moving forward to push air into the room the driver now goes in towards the cabinet "backwards". The same thing happens to the tweeter, unless the phase of the tweeter is reversed in the crossover, so yes there are many variables here. That would be why some speakers are wired at the driver in a reverse phase, RTA 12 is a prime example.
    Ymmv
  • ChrisD06
    ChrisD06 Posts: 912
    Ymmv
    But wouldn't having both speakers wired 'out of phase' still result with them being in phase with each other?
    I didn't notice any differences with the bass honestly, but the M5JR have hardly any bass output (in my room, at least) so that could be why.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,655
    If you are connecting + from amp to - on speaker and - on amp to + on speaker regardless if both speakers are connected that way the speakers are out of phase with the amp.
