Monitor 7 opened up to find a surprise
I’m currently gluing a bunch of my mid drivers magnets.
I’ve had these M7’s for a few years and thought I tested them when I got them but can’t remember for sure. Anyway I opened one up to find something unusual inside. See picture. Any thoughts?
Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
    msg Posts: 10,452
    Huh?
    No crossover?
    xschop Posts: 5,160
    5Jr crossover
  • ratpin
    ratpin Posts: 96
    Anyone have a spare M7B crossover?
  • ratpin
    ratpin Posts: 96
  • ratpin
    ratpin Posts: 96
    Here’s a picture of the crossover in the other cabinet. This is the one I guess I need.
    xschop Posts: 5,160
    Im REALLY curious if the 5Jr crossover has the 34uf, 12uf caps and 2 ohm resistor grafted in?
    Toolfan66 Posts: 18,048
    edited August 2023
    I would like to see the other side of that crossover.
    Post edited by Toolfan66 on
  • ratpin
    ratpin Posts: 96
    Toolfan66 wrote: »
    I would like to see the other side of that cross over.
    Seems like this is as much as I can get without de-soldering.
    edited August 2023
    Ratpin,
    I will be upgrading my 7’s soon, and I plan on doing a point to point crossover, I am waiting on some inductors from HiFi Collective, if it looks like all will go as planned I will gift you a crossover, if you don’t find one between now and then.
  • Gardenstater
    Gardenstater Posts: 4,780
    Yes we need a view of the binding post side and underneath that PCB on the components side. The very early 7s had part of the crossover on the back of the tweeter, not that I'm saying that is what this is.
    You have Monitor 7Cs.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ratpin
    ratpin Posts: 96
    Toolfan66 wrote: »
    Ratpin,
    I will be upgrading my 7’s soon, and I plan on doing a point to point crossover, I am waiting on some inductors from HiFi Collective, if it looks like all will go as planned I will gift you a crossover, if you don’t find one between now and then. It is a perfect match to what you have..
    That would be great! And no I’m not in a hurry. Thank you!
  • ratpin
    ratpin Posts: 96
    edited August 2023
    Yep that’s exactly what’s in the other cabinet.
  • ChrisD06
    ChrisD06 Posts: 927
    edited August 2023
    ratpin wrote: »
    Toolfan66 wrote: »
    That's indeed a 5JR/+ Series 1 crossover.
    It doesn't appear to have any components from the M7 grafted on like Rob asked.
    Also you can get it further than that without desoldering. The resistance is just slack copper wire from the large inductor being very stiff. You can lift it straight up and it'll come out alot further.
    M5JR board is a PITA to rebuild. Anyhow, it looks like you'll be needing to find the correct crossover or make this one spec-compatible.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
    Toolfan66 wrote: »
    Not sure if you received my PM, but I shipped this crossover to you today..
  • Thank you!
