Need help. Polk Lsi15 uneven sound
Answers
    VR3 Posts: 29,540
    Xt25
    No ferrofluid
  • ChrisD06
    ChrisD06 Posts: 929
    edited July 2023
    cuongdocd wrote: »
    I managed to disassemble the Lsi15 tweeter and removed the damaged voice coil diaphragm. Should I rebuild it with the third party voice coil on Ebay ( about $18 ) in order to keep the original tweeter magnet or buy the Peerless (Tymphany) XT25TG30-04 tweeter? ( about $28 ). Are the magnet on these 2 the same type? Also does it helps the sound if I add ferrofluid?
    Just buy the XT25TG30-04 and swap faceplates. Don't add ferrofluid if there isn't any to begin with, could replace the old ferrofluid in the other (Polk) tweeter if there was some from factory as it'd be aging by now but it's fairly tedious to do and you risk damaging the coil.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
