Mach1 Paint
machone
machone Posts: 1,583
My Mach1 is my daily driver and after 19 years it is time for paint. It looks good from a distance but up close there were many spots that were deteriorating.
I was surprised that most shops only work with insurance and will not take on a cash job. Not even a stack of $100s!!
Through connections I finally found someone with the facility and most important the passion to do it right.
Car is completely detrimmed with glass removed. It has taken longer than expected but he is spraying this weekend and I should get the car back in a couple of weeks.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
«13
  • Milito
    Milito Posts: 2,003
    edited July 2023
    Look forward to seeing how it turns out.
    Are you painting it the same color?
  • machone
    Yep
    Colorado Red
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    treitz3 Posts: 20,319
    Lookin' good. Since this is your daily driver....what are you currently using while this is being completed?
    msg Posts: 10,626
    Cheese and rice!
    What a thorough job that looks.
    Must be Earl Scheib.
  • machone
    treitz3 wrote: »
    Fortunately I have access to a company truck.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Well now, that's convenient!
  • bcwsrt
    bcwsrt Posts: 2,658
    That’s some love and commitment right there! How many miles on the car?
    Brian
    nooshinjohn Posts: 26,123
    And I thought this thread was going to let us know where to buy black paint... Thanks for nothing! :D:p:p:D
  • invalid
    invalid Posts: 1,556
    Most body shops don't like doing overalls, they make more money with less work doing collision work.
  • machone
    bcwsrt wrote: »
    174 K
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    There are parts that are black. I'll ask him where he gets his. :D
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Milito
    Milito Posts: 2,003
    edited July 2023
    A friend of mine who used to own a high end body shop taught me how to paint cars right after high school. The part I disliked the most was all of the tape work you had to do along with all of the sanding work. I liked painting, but hated the other part of the process. I painted with lacquer back then. After you painted the car you then had to wet sand it with 600 grit sandpaper and then buff it out. I wouldn't know the first thing about painting a car with the paint that is available now.
    Good quality paint is very expensive now. I'm sure that paint job isn't cheap.
  • chrispyfur
    chrispyfur Posts: 170
    Very cool! These new edge Mach ones always had a place in my heart. Hope you get many more happy years with it.
  • skipshot12
    skipshot12 Posts: 2,133
    Very nice
  • Keiko
    Keiko Posts: 805
    I know where to get some black paint, John. You want some black paint? I know where there's some black paint!
    https://www.youtube.com/watch?v=UVNHcob3oJg
  • machone
    Changed color.
    Did not like the Colorado Red samples. Probably going with Rosso Corsa 322.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Viking64 Posts: 7,791
    machone wrote: »
    Changed color.
    I like Mach Ones in orange, but if you are going to go with a Ferrari color, might I suggest the Rosso Magma? B)
  • machone
    The magma looks great but I am trying not to paint door jambs and Rosso Corsa is close enough that it will not be noticable. Lots of extra work and cost to properly paint the jambs.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Grigio Titanio is a great Ferrari color as well...
    Rosso Magma reminds me of that red used by Mazda...
    edited July 2023
    machone wrote: »
    Then there is only one solution: KICK THEM OUT!!!
    https://www.youtube.com/watch?v=EuZG2Sy7pUU
  • chrispyfur
    Mazda calls it Soul Red Premium, not that anyone was asking... ;)
    msg Posts: 10,626
    Mr. Sheard from 11th grade chemistry was right about you all along when he said you'd stop short of greatness.
    machone wrote: »
    msg Posts: 10,626
    seriously though, that's a hot color, too. I've only had one red car, and I liked it a lot, especially after a day of cleaning it up. '87 Mazda 626GT Turbo in Mazda Sunrise Red. Red with a touch of orange, black trim, tinted windows.
    I think red suits some cars better than others.
    '94 Toyota Supra comes to mind.
    91 Mazda RX-7 Convertible (with targa config)
    @Hermitism 's '96 Mazda Miata with the Blaupunkt that only plays Mr. Mister songs.
    At least it doesn’t play the Saturday Night Fever soundtrack like a ‘78 Trans Am….
  • machone
    I recently replaced the door hinges on the driver's side because the bushings were shot. To get to the hinge bolts the fender had to be removed. To remove the fender the bumper cover and headlights had to be removed. Blah Blah Blah.....kzpjciavunll.jpg
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Final decision made to go with Rosso Corsa. I think I will look great. I'll up date as it slooooowly happens......
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    msg Posts: 10,626
    Wow!
    Like candy!
  • Milito
    Milito Posts: 2,003
    Looks great! Look forward to seeing it finished.
