Even MORE tubes for sale - mixed.
Morer Tubes Fer Sale
All are tested for GOOD on an Hickok 6000a purchased from our own SCompRacer and he got it from Brent Jesse. Some are gooder than others.
Most cleaned but I don't clean if I think the label might come off. There are some original boxes as noted. Boxes may be marked up and as is.
I have no way of testing for microphinics so please don't ask.
If you want a picture of what you're interested in please PM me.
Paypal (Friends/Family) or Cash ONLY. 1st come - 1st served based on date/time of PM. Please indicate what you are interested and what number it is as listed below.
Location is Rockford, IL and at door pickup is acceptable (except for those of you who don't shower... you know who you are.)
No returns - this a fairly flexible plan but tubes are consumables. They will last until they don't (that is the exact time frame).
You pay shipping. Assume at least $10. Depending on where you are and how many you purchased it could be more. If you desire insurance that bill is on you also.
1) 5965 (12AT7 equivilent) RCA, Original box, long gray plates - passes. $10
2) ECC82 (12AU7 equivilent) JJ red label 2300/2400 (2200 = 100%) $10
Each $5
3) ECC83S (12AX7 equivilent) JJ red label, original box - passes.
4) ECC83S (12AX7 equivilent) JJ red label, original box - passes.
5) ECC83S (12AX7 equivilent) JJ red label, original box - passes.
Each $10
6) ECC803S (12AX7 premium equivilent) JJ red label, long gray plates - passes good.
7) ECC803S (12AX7 premium equivilent) JJ red label, long gray plates - passes ok.
8) 12AX7 Russian Svetlana - barely passes $5
9) 12AX7 RCA Orange label, top getter 1150/1350 (1200 = 100%) $10
the following have strange tests. they are called out for 12AU7 equivilent but I'm not sure if my test setup document is correct.
$5 each
10) 5963 (12AT7 maybe equivilent)- RCA White label
11) 5963 (12AT7 maybe equivilent)- RCA orange label, original box
12) 5963 (12AT7 maybe equivilent)- RCA orange label, original box
$20 each
13) 1629 Magic eye - tests for function ok
14) 1629 Magic eye - tests for function ok
15) 1629 Magic eye - tests for function ok
16) 6U5/6E5 Magic eye - tests for function ok $25
Aaron
Enabler Extraordinaire
    pitdogg2 Posts: 27,255
    5963: This is a nice industrial type which is nearly identical to the standard 12AU7. RCA made a nice blackplate version of this tube, Sylvania has a gold pin version, and GE has it in their 5-star broadcast line. The plate voltage rating is a little lower than for a 12AU7, but for most applications, it will work fine. It has a rugged cathode and should be long lived, similar to the 5814. Watch this tube, as it is plentiful now and prices are low. As audiophiles discover it, the rush will be on!
    Per Brent Jesse.
    They never played well in my preamp so I didn't waste much time with them.
  • ALL212
    ALL212 Posts: 1,664
    Last chance
    Aaron
