Tubes for Sale: 5Y3 and 12AU7
Tubes Fer Sale:
All are tested for GOOD on an Hickok 6000a purchased from our own SCompRacer and he got it from Brent Jesse. Some are gooder than others.
Most cleaned but I don't clean if I think the label might come off. There are NO original boxes. Boxes are marked up and as is.
I have no way of testing for microphinics so please don't ask.
If you want a picture of what you're interested in please PM me.
Paypal (Friends/Family) or Cash ONLY. 1st come - 1st served based on date/time of PM. Please indicate what you are interested and what number it is as listed below.
Location is Rockford, IL and at door pickup is acceptable (except for those of you who don't shower... you know who you are.)
No returns - this a fairly flexible plan but tubes are consumables. They will last until they don't (that is the exact time frame).
You pay shipping. Assume at least $10. Depending on where you are and how many you purchased it could be more. If you desire insurance that bill is on you also.
If you are in the market for other tubes please let me know. I've purchased 3 tube caddies full of tubes and have quite the selection.
5Y3 - these are tested good/bad but I kept track of needle deflection so I'm assuming that the higher the number the betterer they MIGHT be. Each side of these are tested at different values. Values are arbitrary!
1) $15 5Y3G RCA coke bottle shaped: 1600/1800
2) $15 5Y3WGTA JAN Hytron Brown base/extra supports 2000/2151
3) $15 5Y3WGTA JAN CBS Brown base/extra supports 2050/2150
4) $10 5Y3GT RCA 1950/2000
5) $10 5Y3GT JAN National Union (RCA markings) 1800/1900
6) $10 5Y3GT Eico (RCA markings) 1800/1800
7) $10 5Y3GT Ge (RCA markings)1750/1800
12AU7 - Minimum for 100% is 2200. All passed, some marginal.
Matched QUAD +1 = $65
1a) RCA Cleartop 2550/2700
1b) RCA Cleartop 2500/2650
1c) RCA Cleartop 2450/2550
1d) RCA Cleartop 2350/2200
1e) RCA Cleartop 2050/2150
Matched PAIR - $25
2a) 12AU7 GE D-getter, Gray plates 2250/2500
2b) 12AU7 GE D-getter, Gray plates 2400/2750
3) $10.00 5814a GE (Newer style tube) 2700/2700
4) $10.00 12AU7a Sylvania round top getter, gray plates 2900/2750
5) $10.00 12AU7a Tung-Sol D-getter, Gray plates 2500/2400
Next post has about 20 6SN7's.
I have grandkids - they get priority. So please have patience...
Aaron
Enabler Extraordinaire
  • ALL212
    ALL212 Posts: 1,664
    RCA 12au7 cleartops are spoken for
    Aaron
    pitdogg2 Posts: 27,255
    edited June 2023
    Any others, need 2 ?
    Or say 12ax7 My preamps power supply uses 1 doesn't need to be special just good and strong.
  • ALL212
    ALL212 Posts: 1,664
    I may have some ax’s - I’ll check and test.
    Aaron
  • kevhed72
    kevhed72 Posts: 5,158
    Any 5751s sir?
  • ALL212
    ALL212 Posts: 1,664
    Seems an odd number but I’ll dig in and see.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    I'll set #5 aside and will assume sold. I know there were some complaints the last time I shipped tubes so I've elected to use UNUSED toilet paper this time for packing.
    You're welcome.
    Looks like some AX's hiding here - hold please!
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Here's what's left:
    Matched PAIR - $25
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    kevhed72 wrote: »
    Any 5751s sir?
    5751 - similar to 12AX7?
    I have no 5751's but will be posting 12AX7's, a couple of orphaned 12AU7's and some 12AT7 equivilantes
    Aaron
  • kevhed72
    ALL212 wrote: »
    kevhed72 wrote: »
    Any 5751s sir?
    Yes similar but not sure if I am brave enough to try them in my pre.
  • ALL212
    ALL212 Posts: 1,664
    I would not go beyond manufacturers recommendations. Because if I did recommend it and your amp blew up...I might feel bad...might... :#
    Play it safe!
    Aaron
    edited June 2023
    kevhed72 wrote: »
    ALL212 wrote: »
    kevhed72 wrote: »
    Any 5751s sir?
    They will work fine. They do have lower gain (70) vs (100) for AX
    ALL212 wrote: »
    You're welcome.
    I'm going to pass, I've hit the tube buying hard as of late. I should buy food and pay a bill.
  • bcwsrt
    bcwsrt Posts: 2,491
    You only have one bill?
    Brian
    bcwsrt wrote: »
    It's a biggin!
  • ALL212
    ALL212 Posts: 1,664
    Still left - you pay shipping.
    Here's what's left:
    Matched PAIR - $25
    Aaron
