SDA Compact
I scored some free SDA Compacts but have a question. My integrated amp is a duel mono which I know is a no no for these speakers. Sadly the speakers are the double blades so I can’t use the A1 to fix it.
That being said, my amp can become a pre amp for something like a tub amp. If I turned my integrated amp into a pre amp but had a common ground tube amp. Would that mess with things? Hope this makes sense.
    F1nut Posts: 51,973
    edited June 2023
    Your Polk SDA CRS speakers will be fine driven the way you describe.
  • khhol626
    khhol626 Posts: 2
    Cool! Thanks for your insight. I felt like it was obvious, but wanted to double check.
