RT3000p plate amp repairs?
ChrisD06
ChrisD06 Posts: 912
I have the schematics, I have the list of capacitors and tools needed, now I just need to know: any advice?
Any common failures I should know of, any list of symptoms to rule out certain problems? Is it even worth $250 CAD to repair them myself or should I spend the extra $400 and just buy new amps?
My gear:
  • Onyko TX-NR656
  • RT3000p L&R
  • CS1000p Center
  • RT35 Side
  • RT35 Rear
    txcoastal1 Posts: 13,499
    If you have the skills and time to choose your parts and repair yourself, then I would do that. At least you know what was done. If you buy used/repaired, and don't know the seller then that's rolling the dice IMHO
    I've attached a couple links from the forum
    https://forum.polkaudio.com/discussion/159800/plate-amp-repairs-for-vintage-speakers
    https://forum.polkaudio.com/discussion/157496/rt3000p-plate-amps-failure
  • ChrisD06
    ChrisD06 Posts: 912
    @txcoastal1 after reading through those posts, it seems like the capacitors are probably my issue.
    One amp board actually worked but I took it out anyways, threw it back in, and voila, it's silent. No humming. Took one look at the factory solder joints and wow oh wow are they absolutely terrible. Probably just gonna reflow and recap and see where it gets me.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    The solder work couldn't be that bad, they've lasted 25 years. I also doubt Polk made the plate amps.
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut
    Looks really bad to me. It works, but it's definitely not what I'd consider quality.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • ChrisD06
    ChrisD06 Posts: 912
    This is a bad trace and here's how it was repaired. Absolutely insane this made it past QC
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    Someone has worked on it.
    F1nut Posts: 51,664
    Since the OP hasn't stated I'd like to know if you bought them new or used?
    VR3 Posts: 29,384
    Yeah I can assure you that is not oem work
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut @VR3
    I bought these RT3000ps used. The amps in them are the originals and I bought them from the OG (since new) owner. He said they were used for a couple years then put in storage for literally like a decade, which is a miracle the amps in these even lasted me a year. All 3 amp boards I have look like this and have terrible joints. One is in a box which says "Polk Audio Genuine Part" or something along those lines, and the other 2 were in the towers.
    It certainly doesn't look OEM, but considering the unused brand new (from Polk in Baltimore) amp looks the same, I'm inclined to believe these are just crap picks from QC. Either way, I'll fix them up. Will run a jumper wire for that bad trace and will recap and reflow the bad joints. Will leave the good joints alone.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    edited May 2023
    There's no way in hell those boards came that way from Polk. Sellers lie all the time and the fact they had an extra amp says to me the seller had amp issues a long time ago. Most likely they had one replaced under warranty and blew that one too, so had some hack repair all three.
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut It's possible. The only thing I don't get is why all of the caps are OEM. They're all the exact same ones used by Polk.
    Though I suppose the issue could have been something other than the caps. Could have been a self repair too...
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    It's easy enough to figure out what's been worked on.
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut Not in this case. The spare amp was still sealed in box in my case, and the banana plug caps were still in place, yet the solder job is still very bad.
    Either way, they lasted 25 years, I'm sure it's good enough, but I'll try to do it even better.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    It's obvious just by looking at your pics that components have been replaced, therefore they didn't come from Polk that way, period.
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut Well now that just makes this DIY repair 8x harder. You think any of those components are going to be bad? Considering lots of these crappy solder joints are on the ICs, which are unobtanium. Maybe I should just sell my RT3000ps at this point
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    F1nut Posts: 51,664
    It's impossible for me to answer that.
  • ChrisD06
    ChrisD06 Posts: 912
    @F1nut better just try the repair then. Good news is I was wrong about all 3 having bad solder joints, it was just lighting, the new one has amazing solder joints and I'll use that as amp #1, but the other amps are scaring me.
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
  • ChrisD06
    ChrisD06 Posts: 912
    edited June 2023
    Reviving an old thread. One of the amps worked fine. Even in working condition, I took it out of the subwoofer, let it sit for around 11 months, powered it back up and it didn't work at all. Repaired the joints on 2 connectors, replaced the filter capacitors, and it does the exact same thing.
    No hum, no click from the relay, no nothing. Any ideas?
    I think I did a pretty good job with those caps though!
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
    Need more pics of what looks like a hot mess
    See circled in green
  • ChrisD06
    ChrisD06 Posts: 912
    Okay update:
    The auto position didn't work. I tried what I thought was the on position... turns out that was the off position. I tried the on position this morning AND HOLY SMOKES THEY WORK. AND EVEB BETTER IS THE AUTO POSITION WORKS TOO.
    I think the caps in the preamp board were just so discharged that they couldn't send a signal to the amp board to engage the relay, so when I charged them up it fixed that. I mean wow, just wow. I am thoroughly impressed with myself for somehow managing this feat.
    Time to go for number 2, baby!
    My gear:
    • Onyko TX-NR656
    • RT3000p L&R
    • CS1000p Center
    • RT35 Side
    • RT35 Rear
