RCA 6SN7’s Question?
Toolfan66
Toolfan66 Posts: 18,048
So I purchased this lot of NOS RCA 6SN7GTB’s
9 of them look a little different, the base is shorter, the diameter is about 1.45, and there is a hair thin wire you can see going across the top.
The other 4 of them have a taller base, diameter is about 1.65, and no hair wire going across the top.
Outside that the build between the two look the same.
Different manufacturers?
I actually like the look of the taller wider base, but not like you will see them.
What do you Tube guru/nerds think?
