Do any have crossover schematic for monitor 5 series 2?
I need crossover schematic for my polk audio monitor 2 series 2.
Mw6502
Sl-2500
sw83
Answers
  • Gardenstater
    Gardenstater Posts: 4,780
    It would be in Vintage Speakers/Schematics all except SDA but I don't see it. would say M5s or M5s rev2. I only see the M5b and the tl mod (SL3000) to the M5b, which would also work with the SL2500 but I doubt that is very close to the circuit you have.
    You'll have to look at what you have and maybe we'll learn something, but inductors need a meter with more capability than the standard meter has, to measure.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,045
    I'm pretty sure the M5b SL3000 schematic is the same as the one he has. The SL2500 has a large and small tab to connect to the wiring. The RD-0198 is a drop in replacement for the SL2500.
    IF his crossover also has a 5.8uf cap across the resistor it's very likely it is the same.
    txcoastal1 Posts: 13,512
    @JiLoq
    Can you provide a couple pics of your crossovers?
  • Gardenstater
    I guess we'll see. But if you look at the date in the SL3000mod for the 5B, I believe it is prior to the date that the M5 series II came out. Take the M10 schematics for example. The M10s rev2 schematic is dated March 1990 and the SL3000 mod is dated July 1989. The two schematics are significantly different.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,763
    JiLoq wrote: »
    Mw6502
    Sl-2500
    sw83
    Remove the crossover, you'll find the values printed on the components.
    F1nut Posts: 51,763
    edited May 2023
    @CFarrell_SoundUnited
    This thread needs to be removed from the section.
  • JiLoq
    JiLoq Posts: 5
    JiLoq wrote: »
    Mw6502
    Sl-2500
    sw83
    I don't have any crossover 🙁
  • JiLoq
    JiLoq Posts: 5
    txcoastal1 wrote: »
    @JiLoq
  • JiLoq
    JiLoq Posts: 5
    Sorry I don't have any crossover to look at.
  • Gardenstater
    @CFarrell_SoundUnited In this case, since we replied to a thread that is in the wrong section, could you just move it to another section?
    @JiLoq I see. So you bought speakers that someone had removed and sold the crossovers?
    That's a predicament. You could probably copy the SL3000mod crossover then, if you can't get the crossover schematic from someone here. The exact Series II crossover would be preferable though.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    @JiLoq Here is the M7 Series II crossover that has the same active drivers. Of course, this speaker has a larger enclosure volume and therefore a different passive radiator but I wonder if the crossover was electronically the same as your M5 Series II.
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18774.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • MikeSowsun
    MikeSowsun Posts: 9
    edited January 2025
    If anyone is still looking, I took some photos of my M5 Series 2 crossover showing the Cap values. I also took the M7 Series 2 crossover schematic and modified it to show those values. The only difference I can see is the C2 cap values. I don’t know what the inductor coil values are, but I suppose they would be the same or very close to the M7 values.
  • Conradicles
    Conradicles Posts: 6,343
    More pictures coming soon for reference. I just acquired a pair of these.
  • Conradicles
    These cleaned up nice. Might offer up these as a forum karma.
  • skrol
    skrol Posts: 3,450
    The design engineer is a personal friend of mine and I'll ask if he recalls the inductor values.
    Stan
    Main 2ch:
    HT:
    Other stuff:
