SDA SRS 2 Bi-amp Tube and Solid State advice
I just came into possession of a mint condition pair. Yesterday I decided to try bi-amping them using a Dynaco ST70 Series 3 (the 2016 version from Radial Engineering) for the mid-high, and a McIntosh MC2105 for the bass. The ST70 is 35 watts per channel and the McIntosh is 105 watts per channel. Both amps have level control so I set the ST70 at full and the MC2105 at around 50% which seems balanced. It sounds very good. My question is that the specs list the nominal impedance as 6 ohms. Would this still be 6 ohms in the bi-amp configuration? I am using the 8 ohm taps on both amps. Any suggestions and observations would be appreciated.
Other components:
Acurus Act 3 Preamp
Schiit Audio LOKI MINI+ Tone Control
Best Answers
Answers
    pitdogg2 Posts: 26,922
    Sticker is incorrect, what you have there are SDA SRS 2.3, I also cannot remember so refresh my memory. I'm under the impression those were not a Blade/blade interconnect cable set. I thought they were late enough to actually be the Pin/blade interconnect.
  • Lee Berger
    Lee Berger Posts: 15
    edited April 2023
    I thought so as the image search for the SRS2 shows a different model.
    Image is prior to bi-amping. The original jumpers were missing.
    edited April 2023
    To be sure really need to see the socket or cable end.
    I'm pretty sure all real Blade/blade models were outside the cup. Early pin/blade did actually use a B/b socket but were wired differently and inside the cabinet and socket was inside the cup.
    I do feel yours are a P/b model.
    Post edited by pitdogg2 on
    audioluvr Posts: 5,865
    Lee Berger wrote: »
    I'm pretty sure that cute little subwoofer is useless now.
  • audioluvr wrote: »
    Lee Berger wrote: »
    Ha! It’s actually part of the TV surround sound system. The Polks are for 2ch music.
  • Lee Berger
    edited April 2023
    The Polk SDA Handbook confirms your assumption:
    The cabinet dimensions line up with this chart also from the Handbook
    Upgrade the crossovers and tweeters ( with Polk RD0-194's and you'll have a very nice set of speakers!
    Can you recommend a source for RD0-194’s? I recapped my RTA 12B’s recently. I’m not sure it improved anything. I used quality caps. I’ll visually inspect the 2.3 crossovers for leakage. That is when I figure out how to get to them🧐😁.
    Make sure you tell them you want RD zero 194.
    F1nut Posts: 51,666
    Lee Berger wrote: »
    audioluvr wrote: »
    What brand/model of caps did you use?
    You won't see any leakage. Electrolytic caps have a useful lifespan of 10 to 20 years max. Yours are way past that.
    Remove the PR to gain access to the crossover.
  • invalid
    invalid Posts: 1,441
    Most caps don't leak electrolytes, they leak electrically.
    edited April 2023
    invalid wrote: »
    Ummm you never experienced Elna Dourex II caps. They were some of the most corrosive caps I've ever had experience with. Well after I recapped my Sony 33es CD player I was going back in to fix the traces they puked onto the copper traces and continued to eat away at long after they were gone.
  • invalid
    I know there are some caps that leak electrolytes, but they are usually defective from the start.
  • I remember in the early 2000's there were surface mounted electrolytics that leaked in Sony and Panasonic professional video equipment (cameras and recorders) I was using at the time. A local tech was doing a pretty good business replacing those caps. He would photocopy the board and check them off as he did the replacements.
  • Lee Berger
    edited April 2023
    Lee Berger wrote: »
    audioluvr wrote: »
    Some were Bennic, Audiophiler, and another brand that I can't identify. Pic below if anybody knows by the logo.8o484ittihqm.jpeg
    F1nut Posts: 51,666
    edited April 2023
    Bennic is the same as Dayton, both horrible. The electrolytic is a Solen. As a 27uF film cap is readily available there's no reason to use an electrolytic there.
    Judging by the price of the Audiophiler caps I'll go out on a limb and say they are crap.
    Lee Berger wrote: »
    Many of those were counterfeit nichicon and others coming out of China, yes it was bad.
    edited April 2023
