My Acoustic Baffle Ceiling Work
AnnaJohns
I have designed ceiling with sound absorbers for acoustic comfort and the tool used to create the design is 3D Max. The inspiration for the ceiling pattern is Lattice, an open framework that are crisscrossed to create a variety of designs and expressions. In this design, ceiling baffles are traversed to create a grid. The below one is the final output of the design.
Product: Acoustic Panels
Software: 3D Max
Software: 3D Max
Can you hit them with black paint?Don't take experimental gene therapies from known eugenicists.
