Can I use this Amp with SDA's?
Just picked up in Onkyo M-506rs power amp and wanted to be sure it was safe to use with some sda-2s I have. Can't find info if this amp is common ground or not. If anyone has any information that would be great, don't want to damage this thing.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,295
    edited April 2023
    From the circuit schematic it appears the speaker negatives are tied together, so it should be fine with a common ground speaker connection. You should be able to place one probe on the left speaker's negative terminal and the other probe on the right speaker's negative terminal with a Volt/Ohm meter set to resistance and read "0".
  • Great, thanks for the reply. Just to clarify, if I do as you instructed with the multimeter and get a zero then I am good to go?
    nooshinjohn Posts: 25,978
    yes...
  • When set to resistance I get a 0.2 reading
  • RTally
    RTally Posts: 15
    edited April 2023
    Hansen2112 wrote: »
    Now touch the two meter leads together. Do you still get a 0.2 ohm reading? If so, you are good to go because you are measuring the resistance of the leads and meter connection (plus any zero offset of the meter).
  • Yes sir, that's what I got. Thanks for the help and explanation, much appreciated!
