WTB Bryston speaker switch
WagnerRC
If anyone know's of anyone looking to sell. I am looking to buy. Thank you
What about the Bryston has you hunting for one? Adcom made some great switches. The gfs-4 in particular has absolutely nothing in the path other than the switch. Internal wiring is heavy duty. Quality 5 way posts. I have one that I've been using for probably 20 years to feed multi-zone audio. Also have a gfs-300. Same quality posts. Load balancing is selectable. I dislike the Adcoms with the flakey twist locks.
Thanks Dave. I was looking at the Bryston SWB4. I really like the bryston connections. But I will take your advice on the Adcom too. Much easier to find the adcom for sure. Thanks for your input and the twist locks was my holdback too.
