New Dual Linear Power Supply
13»
    treitz3 Posts: 19,992
    So long as you have the needed amperage? You are golden. You can always have over amp ratings but you don't want to under amp.
    You should (IMNSHO) just say F it and put everything ya' got together and hook it up....then listen.
    Forget the testing. You can always do that later. Run with what ya' got and enjoy the music brother!
    Yes, this includes the ER!
    heiney9 Posts: 25,432
    The iFi's are 12V 1.8A units. The modem is 12V 750mA the router is 12V 1.5A so those would be fine. The Keces will run the Node3 and ER with much left over capacity.
    Tuesday night I will have some "alone" time after work for about 2-3 hours. I plan on getting the ER going then and having a listening session. I'll just be using the supplied power supply to begin with. Then when I have more time to reconfigure the entire rig, I'll incorporate the LPS for both the Node3 and ER.
    After hearing the USB REgen, I'm anxious to hear the ER.
    edited March 2023
    Hehe...I bet you are!
