What Does the Green Vs White Vs Amber LED lights mean on front of SB1+
I typically watch cable and stream movies on the system that is connected to the SB1+. I notice when I watch cable the Optical (Source) LED light on front of Sb1+ is White or Green. I am assuming this indicates the stream type, ex. Dolby, LPCM (Or Other). Does anyone have any clarification on this. This will help me determine my audio stream while streaming.
Thank you!
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Answer ✓
    Hello,
    Here is an explanation of the LED's function:
    A single red LED means the unit is in the "standby" mode.
    A single orange LED means "source 1" is a PCM device
    A single green LED means "source 1" is a Dolby Digital device
    Two orange LEDs mean "source 2" is selected
    A single blue LED means "source 2" is a Bluetooth device, blinking blue LEDs mean the device is not connected.
    When white LEDs are blinking "mute" is engaged, "volume", "voice" and "bass" will have white LEDs when being activated.
Answers
