Where to find info on amps?
smalltownheel
smalltownheel Posts: 39
edited March 2005 in Speakers
I have a denon 2803 and was told I need an amp to push the LSIs I'm going to buy. I have the LSI15s and am thinking about getting a LSIC, either LSIFXs or LSI7s for surround, and am trying to figure out which sub to get and what kind of amp to buy.
Post edited by smalltownheel on
  • Frank Z
    Frank Z Posts: 5,860
    edited March 2005
    Not trying to be a wise-****, but use the search button in the upper left corner below POLK. Do a search for amps and you'll be provided quite an extensive list of threads to look at.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited March 2005
    That and give us a budget...
    More later,
    Tour...
    Vox Copuli
  • smalltownheel
    edited March 2005
    preferably below $600
  • smalltownheel
    edited March 2005
    no harm done Frank. as you can see i just started using this site. i think i'm addicted.
  • Tour2ma
    edited March 2005
    $600 for sub and $600 for amp, or $600 altogether?
    Also, are you open to used gear?
    More later,
    Tour...
    Vox Copuli
  • smalltownheel
    edited March 2005
    $600 each, but mainly i just want to make sure i get a good quality match to go with my other equipment. I'm flexible when it comes to budget. And I've never bought any used equipment so I don't know how much confiedence I have in buying something used. But am very open to suggestions, whether to go used or new. And I've never bought a HT amp, so I don't know how much u need to spend to buy a good one.
    thanks
  • smalltownheel
    edited March 2005
    I'm just lost when it comes to this stuff. And I really appreciate all the advice I have received already in the short time that I've been visiting this great site. I thought i new a little about audio, but when i found this site i realized i don't know anything. What would you suggest I do if I wanted to know everything there is to know about the audio world, outside of researching this site.
  • smalltownheel
    edited March 2005
    thanks Frank, and thats a nice HT system you've got there
  • Tour2ma
    edited March 2005
    Club Polk is all about sharing views, experiences, opinions... some are further along the "curve" than others, but we are all learning...
    Certainly, CP is one of the more down to earth Forums I've visited, but there are others that aren't all that daunting. Some center on other brands, some on HT, some on vintage gear... all depends on what info you want to pursue.
    Library is an oft overlooked source... there are some worthwhile books.
    Plenty of web-site hits for searches on any specific topic... here's a good, general reference...
    http://www.audiovideo101.com/dictionary/
    Got your budget set now, but you did not answer the question about used equipment... Would you consider used gear?
    More later,
    Tour...
    Vox Copuli
  • Frank Z
    edited March 2005
    Your welcome sir and thank you!
  • smalltownheel
    edited March 2005
    yes i'm open to the idea of used gear
  • Frank Z
    edited March 2005
    Call Russman...BR549.;)
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2005
    Russman,
    Does everyone pick on you ?????????
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Tour2ma
    edited March 2005
    Nice to see that Frank and I recommend the same site... and Russ may come into play... wouldn't bet against it.
    OK, used gear... Great...
    I'm assuming you are presently running a single pair of speaker wires to your 15's with the brass jumpers in place. Also assuming that you have your LFE routed to the Mains... yes?
    Anyway, first you can play with your set up some and get a taste that will yield some direction.
    While your 2803 is wired internally to get a signal to each of its 7 amp channels, I think a given channels "pre-out" can be used without interrupting the internal signal. We will need to verify this at some point. But if it's as I think it is, this opens up all kinds of flexibility.
    Two of your 2803's channels are assignable to a 2nd zone. Do this with them getting the "Mains" signal. Zone 2 has independant volume control, a pain, but for playing it'll work...
    Most Polk speakers with dual binding post pairs have the top pair feeding the tweeters and the bottom the mid-woofers (MW's). Your 15's are a little unusual in that they have a subwoofer... of sorts.... that handles frequencies below 150 Hz. So the 15's bottom posts feed the "sub", and the top pair the MW's and tweeters.
    With the 2803's LFE routed to the Mains, wire the Mains to the 15's sub. Then make a second wire run from Zone 2 to the 15's MW's/ tweeters. REMOVE the brass jumpers before connecting the speaker wires...
    With the above done, you haven't quite doubled the power to your mains (AVR's are normally more powerful in 2 ch operation than when additional ch's are in play), but you should be a good 50% stronger... 180 wpc vs 120...
    See what you think, particularly of the bass. It'll tell you how much of a sub you'll want, and if 200 wpc or so for the front stage is in the ball park...
    Later...
    More later,
    Tour...
    Vox Copuli
