Advice on switching up my streaming setup.
stangman67
Fellow Polkies,
Considering switching up my streaming setup. As of now I have a Cambridge 851N feeding a NSD Intenso Dac running Tidal.
I am considering picking up a Mac Mini and going USB out to a Gustard or Denafrips R2R DAC and using Roon.
Considerations for me, I am unfamiliar with the capabilities to control Roon from an app on my phone, that is really what I would like to have happen as I don’t want to have to use a keyboard and mouse and my TV to pick music. Has anyone tried to use Switch Control on a Mac for these purposes?
To all your more experienced streamers out there, does this upgrade path make sense? I really want to try a R2R dac but I don’t want to spend massive bucks on a streamer in the future if I can get similar performance out of a Mac feeding the dac directly.
Or is Roon remote the solution for this?2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
In order to try the new DAC can't you just simply swap the Denafrips DAC for the North Star and leave everything else as is? I'd rather have the 851N as a streaming transport.
Are you unhappy with the app interface for the 851N as well? -
I could certainly go that route but I’d like to simplify stuff a bit. It would gain me valuable space on my rack. I don’t mind anything about the 851N. Sounds good, good interface, reliable. I just want to try something new.
I imagine digital out on the Mac Mini will sound just as good as the digital out on the 851N. DAC is the big piece of the game here.
But before I jump in, I’d like to hear opinions from people that have a setup like I am looking to do. IE stream from a computer as a Roon endpoint basically2 Channel in my home attic/bar/man cave
Soon remote on an iPhone is just a great, slick app. Highly recommended.
I have not tried it, but usually, computers introduce noise that dedicated streamers do not. I wouldn't recommend it.
I know I will get flack for this, but I compared a Logitech squeezebox touch with enhanced audio output applet installed, hardwired ethernet, and bolder power supply used as a Roon endpoint, and with an external DAC and the same cable? Couldn't discern enough of a difference to justify the Cambridge. I definitely felt like it made more sense to put that money into an amp or DAC...just my experience...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
stangman67 wrote: »I could certainly go that route but I’d like to simplify stuff a bit. It would gain me valuable space on my rack. I don’t mind anything about the 851N. Sounds good, good interface, reliable. I just want to try something new.
The streaming transport itself actually makes a big difference, hate to say it.
Using a PC as the streaming transport isn't "ideal", not to mention that Roon imparts it's own sound quality - which I didn't personally care for. YMMV.
I hear ya on the rack space issue though, I don't like stacking components. -
Agree. Streaming transport over pc every time- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good points. I get that a high end streamer is probably a better option but what is harder is deciding where the equivalent price point is. Forking over the cash on a high end dac AND streamer is just hard to swallow. I’m not sure if the Mac Mini straight to a DAC is a good idea, just piqued my interest after I watched a YouTube video my Paul Gowan about his use of a Mac as a streamer and he seemed to be a huge fan of it in a very high end setup.2 Channel in my home attic/bar/man cave
Step one, stop listening to anything Paul McGowan has to say.
My thing at this point is I know my streaming setup is leaving a lot on the table. Maybe I’ll have to upgrade the dac and then upgrade the streamer later on down the road2 Channel in my home attic/bar/man cave
Of course, but my point is you have to go pretty high end to get better than what I have (probably 2k or higher for a dedicated streamer, no DAC), and I am not willing to pay that, and even if I was you then have to decide which makes the bigger difference: source, DAC, preamp, amp, or speakers (not to mention cables). I felt that I could make a bigger impact in other areas...perhaps @stangman67 feels the same...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Yea I’m at the post where I am happy with the the pre/amp/speakers/vinyl setup and cables. Really the digital side of the house is the last part to be upgraded and I just need to decide where I should be targeting my budget. I don’t want to spend 5g’s on a dac and streamer so at this point the DAC probably makes most sense to upgrade2 Channel in my home attic/bar/man cave
With streaming it literally all matters man. It has been mind blowing to me how much performance can be extracted and I'm sure I haven't even uncovered it all.
Linear power supplies... Modems routers... Ethernet cables... DC power cables... Switches between the router and streamer... Filters....
The actual steamer and dac is only part of the equation...
And the cable between the streamer and dac is important
Power supply for the streamer is insanely important!
Of course the dac is important
If your goal is ultimate performance, the path is long, deep and expensive!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Alternative option: Sell the 851N and the NorthStar and get an AIO streamer like a Vega G1/G2, Lumin T3, or Aurender A200.Post edited by Clipdat on
I have a spouse and four amazing children. I enjoy my house, vacations, good food and wine, making sure my kids get a great education, etc. All those things cost lots of $$$.
Ultimate performance never has been nor ever will be my goal. Carry on...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
No doubt!
You can sensibly upgrade your streaming thru good deals and keeping it realistic.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
stangman67 wrote: »My thing at this point is I know my streaming setup is leaving a lot on the table...
That’s awfully pedantic.
Thanks for the input all. I’ll have to re-evaluate what my goals are and what I’m willing to spend to get there. I’m not unhappy with the way it is now, but I SUSPECT I can make some serious improvements with the streaming setup.2 Channel in my home attic/bar/man cave
Never know until you try. Do you have a local Auralic/Lumin/Aurender dealer who would let you do an in-home demo?
Edit: Nevermind. I keep forgetting the fact that you want to go with the R2R DAC option. -
Im in an audiophile dead zone. No dealers within 4 hours. DC is the closest hub with some decent dealers2 Channel in my home attic/bar/man cave
Ank dac!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
How involved is the assembly. The 2.1 Signature is intriguing2 Channel in my home attic/bar/man cave
I would go for the 4.1 pro, after current discount is under 3k. That is fully assembled
Phenominal dac- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Is that the one that you have?
I have the 5.1 pro with the quad c core
Owned the 4.1 before the 5.1- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well then the 5.1 pro is the one to get. Don't settle for anything less.
I had the 851N. Streaming Tidal off my phone, to me, sounded bloated but using my laptop and a USB cable (which has a very good sound card) sounded much more natural, like a CD would. Now I just run a Gustard DAC and whether I use my phone (Bluetooth) or laptop (USB) they both sound fantastic. Navigation is better via laptop though.Gustard X26 Pro DAC
Do you mean controlling tidal through your phone, as in tidal connect, or were you casting tidal? Big difference, and using connect or the magic stream app should sound much better…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Using Cambridge connect or StreamMagicGustard X26 Pro DAC
I never used the Bluetooth feature on the 851Gustard X26 Pro DAC
Etymology
The name "Bluetooth" was proposed in 1997 by Jim Kardach of Intel, one of the founders of the Bluetooth SIG. The name was inspired by a conversation with Sven Mattisson who related Scandinavian history through tales from Frans G. Bengtsson's The Long Ships, a historical novel about Vikings and the 10th-century Danish king Harald Bluetooth. Upon discovering a picture of the runestone of Harald Bluetooth in the book A History of the Vikings by Gwyn Jones, Jim proposed Bluetooth as the codename for the short-range wireless program which is now called Bluetooth.
According to Bluetooth's official website:
Bluetooth was only intended as a placeholder until marketing could come up with something really cool.
Later, when it came time to select a serious name, Bluetooth was to be replaced with either RadioWire or PAN (Personal Area Networking). PAN was the front runner, but an exhaustive search discovered it already had tens of thousands of hits throughout the internet.
A full trademark search on RadioWire couldn't be completed in time for launch, making Bluetooth the only choice. The name caught on fast and before it could be changed, it spread throughout the industry, becoming synonymous with short-range wireless technology.
Bluetooth is the Anglicised version of the Scandinavian Blåtand/Blåtann (or in Old Norse blátǫnn). It was the epithet of King Harald Bluetooth, who united the disparate Danish tribes into a single kingdom; Kardach chose the name to imply that Bluetooth similarly unites communication protocols.
