Looking for factory spkr screws for mounting drivers......etc
Looking for factory screws for mounting hardware drivers in Monitor 10's, SDA2 and CRS cabinets , or the screw specs will do also . Iam redoing a bunch of units and would like to use new mounting screws vs current rusted and or replace missing ones . ~ Long and short of it ... the ones that came with the units were nicely and neatly put away , but ..... some how the whole bunch just happened to disappear some time over the last holidays (putting it nicely) . So I need a whole bunch of these little black beauties (again or the specs of said screws) Seems there were all about the same or possible only two sizes between the above mentioned units . ~ Thx for the help , my little clan of Polks also thank you !
SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • Gardenstater
    Gardenstater Posts: 4,780
    edited January 2023
    I can only speak for my 7Bs but what Polk used was a #8 x 3/4" Phillips Pan Head Black Oxide Sheet Metal Screw (fully threaded to head). Parts Express sells one that is a coarse/deep thread version. Root diameter is smaller and helix angle is greater. They work fine for new holes which is what I used them for on my Passive Radiator to go from 4 holes to 8. I always make sure I put them back in the same places to not mix up the types.
    https://www.parts-express.com/8-x-3-4-Deep-Thread-Pan-Head-Screws-Black-100-Pcs.-081-422?quantity=1
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Jazzhead
    Jazzhead Posts: 526
    I've found identical screws (in my case, for 6500's) at the hardware store. That said, hurricane nuts and machine screws are superior in terms of sonics (attack and slam), and they don't strip out over time (removing/replacing drivers in the process of upgrades). They do involve some detailed work...
  • Gardenstater
    Yes, maybe those screws disappeared for a reason lol. Time to upgrade? Rob's semi rings would be my recommendation.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • stereo55
    stereo55 Posts: 418
    Thanks gents for all the suggestion ,they are all fantasic! Youve been a great help to this old Polk **** . Very much appreciated !!!
