PSW 505 Powered sub woofer not working
Nicksteroni
Room set up - Sonos amp channels run to the powered sub woofer. From the subwoofer to my two room speakers. It's worked perfect for years. Sub woofer went bad. Replaced the unit with a new one I had in another room. Everything is identical as previous, all is powered and it is not working. I have music in the speakers perfectly fine but no sub woofer. Thoughts?
Answers
Nicksteroni wrote: »Room set up - Sonos amp channels run to the powered sub woofer. From the subwoofer to my two room speakers. It's worked perfect for years. Sub woofer went bad. Replaced the unit with a new one I had in another room. Everything is identical as previous, all is powered and it is not working. I have music in the speakers perfectly fine but no sub woofer. Thoughts?
Sorry but a dayton SPA-250 amp from parts express or a new sub from a different brand are probably your best bets…Polk subs are not good…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
