Back box size for polk rc80i?
Hello polk audioholics! New here.... Im getting ready to install my atmos speakers and wanted to add a back box and some fiberglass (my first floor ceilings are hollow) and wanted to know what size back box I should use for these speakers? Thanks!
    txcoastal1 Posts: 13,513
  • So unfortunately that solution won't work for two of my speakers as the cutout is right up against a joist. See photos.sf3ww4ijx36k.jpg
  • Can anyone help?
    Leave the cavity open directly above the ceiling speaker, but stuff insulation inside the chase all around that cavity.
    In-wall speakers are in-wall by design. The reason I used the Dynabox was my speakers were exposed to my attic
    edited January 2023
    They are but soft enclosure improves sound and dispersion ....especially in in high sub-floor as in pics
  • Thanks for the input! I really didn't wanna deal with back boxes anyways, insulation should be fine.
  • @mod ok to close thread.
    VR3 Posts: 29,429
    Enclosures do nothing for an infinite baffle
    The bigger the infinite space, the better!
    The only way I would recommend an enclosure for infinite baffle is if the manufacture recommends its.
    Otherwise you just need to make sure the front wave and back wave never meet and you are good.
    You could even mount the drivers firing outside your house towards the neighbors to share the love.
