Banana plugs
Does anyone know what kind of banana plug to use for Polk T15 speakers?
Answers
    F1nut Posts: 52,162
    edited January 2023
    Any banana plug will work after you remove the plugs in the binding posts.
  • Emlyn
    Emlyn Posts: 4,868
    This model (https://www.polkaudio.com/en-us/product/bookshelf-speakers/t15) uses standard "five way" binding posts. They'll take speaker wire terminated with any standard banana plug, spades, or bare speaker wire. Plain speaker wire works fine by itself. Banana plugs can be more convenient.
