Sistema AV 5-7-9.1 para 4xR200 + R400
POLKMenesteo
in Electronics
Hola amigos,
Hace un par de años actualicé mi antiguo KENWOOD KRF-5010 por un PIONEER VSX-934. Hace dos meses jubilé mis MISSION serie 700 + 732i + SOLID (B&W) y los sustituí por dos pares de POLK R200, un R400 para el canal central y un Subwoofer HTS10. Desde entonces he comprobado cierta mejoría con respecto a los MISSION, pero siento que el PIONEER no está a la altura de estas magníficas cajas y no le sacan todo el rendimiento y potencia.
Os agradecería que me aconsejaseis algún sistema AV de calidad media alta, que esté a la altura de estas cajas y pueda sacarle todo su potencial.
Gracias y saludo...
Gracias y saludo...
Translation:
Hello friends,
A couple of years ago I upgraded my old KENWOOD KRF-5010 to a PIONEER VSX-934. Two months ago I retired my MISSION 700 series + 732i + SOLID (B&W) and replaced them with two pairs of POLK R200s, an R400 for center channel and an HTS10 Subwoofer. Since then I have seen some improvement over the MISSION, but I feel that the PIONEER is not up to these magnificent boxes and they don't get all the performance and power out of it.
I would appreciate it if you could advise me on a medium-high quality AV system that is up to these boxes and can get its full potential out of it.
Thanks and regards... -
POLKMenesteo wrote: »Hola amigos,
Gracias y saludo...
Welcome to club polk!
I would look for an AVR with preouts in case you want to add a separate amplifier down the road. This would be a good choice: https://www.accessories4less.com/make-a-store/item/yamrxa1080bl-rb/yamaha-rx-a1080-7.2-ch-x-110-watts-a/v-receiver/1.html
If you give us a budget and location it might be easier to help you…Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Gracias y saludo...
Gracias por tu rápida respuesta,
Mi idea era un AVR entre 2000 y 3000€.
Saludos.
