New L800 Speakers Just Arrived - Now Which Centre Speaker?
My new L800 (in black) just arrived. Am breaking them in.
When unpacking I noticed there was an SDA cable in each speaker box, so there are 2 cables. Is this so they can connected together to used as a long cable?
Right out of the gate the imaging is insane. The sound stage is big and the vocals in the middle are solid. Even if I sit off centre it's still there.
I had the 1.2TL 10+ years ago and I don't believe these sound as good as them. However my memory of how they sound my not be totally accurate and my hearing has likely degraded over the years.
I'm hoping the tonal characteristics will change as I break them in, at the moment it's a little bit bright.
So far after less than a day I am very happy with them. Maybe wished I'd gone for the walnut though.
In terms of centre speaker ... Because the R series uses the same drivers, I am assuming the R400 would be an ok match for timbre/tone. Since the R400 is so much cheaper than the L400, is the L400 that much better to justify the price?
I guess that's a really long way of asking
R400 or L400 to go with L800?
The L800 replaced 1.2TL’s that had been fully restored. You have a solid month of break-in time ahead of you before you will start to really hear what they can do. As far as the center goes… yes, the L400 is that good.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
L600- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
R400 would be fine. L400 would be perfect. I have both and swapped them around a couple times. The main drawback to me is the L400's size. The R400 will fit in/on my Salamander rack but the L400 has to go on a center speaker stand.
FWIW, the LSiM center speakers do very well too in blending with the L800s.
Congrats on the new speaker experience.
There is an SDA cable included for each speaker in case someone has to route the cables in such a way as to need a longer length than just one cable provides. They are designed to connect together for that purpose. I just use one.
The L800s take a while to open up and demand a high current amp. I recommend taking the rubber feet off and using the spikes beneath those. The rubber feet made my speakers sound a bit vague and not properly focused. Much better sound without those.
FWIW, if you look for aftermarket spikes the thread size for those is M12-1.5 -
This surprises me, the sitting off center bit.Right out of the gate the imaging is insane. The sound stage is big and the vocals in the middle are solid. Even if I sit off centre it's still there.I disabled signatures. -
Nothing wrong with your memory.Political Correctness'.........defined
President of Club Polk -
IMHO...The L400 is by far the best center Polk has ever made, sound is great.
Example:
LSiC
21-1/8"W x 7-1/16"H x 9-1/16"D
21.125x7.063x9.063
1352.253 cu in
L400
26"W x 9-1/2"H x 13-1/2"D
26x9.5x13.5
3334.5 cu in
2.47 times larger
The LSiC was the weak link in the LSi series. The RTiA6 center in the RTiA series was much better sounding center, than the LSi flagship series.
I actually installed LCi-RTS-C in-wall speaker in a DIY box because the sound was so much better, when I had a Lsi home theater system.
I now have the L600 w/900 atmos modules, L400 canter, L100 for rear chnl, and for still have LCi8's in ceiling for rear atmos, and 2-SVS 4000 subs
System is great2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I figure the L800 is more on par size wise with something around the old SDA 1C level. But, add a good Rel subwoofer or two and the system performance is boosted a lot. Not required at all though.
Thanks for the quick reply everyone. Kind of confirmed what I was suspecting.
The R400 is fine, but the L400 is better and worth the money. I guess I will bit the bullet and get that.
For the rest of the system I will be using different speakers. I have 4 x on wall for surrounds and rears. I don't believe there is a speaker in the L series which are slim on wall, and I don't believe the surrounds have to match the LCR.
I will also be leaving my current 4 x ceiling speakers. Again, I don't believe they to match and current there is no L series celling speakers. I was told years ago that ceiling speakers were better than top speakers like the L900 for ATMOS/DTS:X, so I have gone that route.
I'll need to measure to see if the L400 will fit -
You're going in the right direction.
let us know how it all pans out...Merry Christmas2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
