Monitor 7 Baffle Strengthening
I'm in the process of veneering my beat up 7B's and, while I'm waiting for the veneer to arrive, I decided to install hurricane nuts and also the semi rings that I've had laying around for too long. Others have mentioned that the baffle between the MW and passive radiator is possibly a weak point on this model that could use some stiffening up. I made these and was going to just screw them from the inside into the cabinet. I know most here like mods the can be reversed, so no glue! Thoughts? I had the oak scraps and the free time so if it's not practical I have nothing to loose.
  • Nice you beat me to it. Let us know if you hear any improvements!
    I will be using a couple round 1" oak dowels in 2 pairs of glued in wooden sockets, like the way a closet rod is supported. If I like what I hear the dowels will get epoxied for good.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 51,918
    joebass3 wrote: »
    Can't hurt.
    xschop Posts: 5,324
    edited December 2022
    This mod cleans up the mid-bass substantially.
    Less energy will be wasted exciting the baffle.🙂
    Nice method you used to be able to quickly swap and compare too.
    Post edited by xschop on
  • joebass3
    joebass3 Posts: 311
    My scraps of wood were free, but I had also thought about this as an alternative. It could be easily adjusted for a tight fit and then attached. But would a metal rod be OK? How close is too close to the speaker magnet?
    Post edited by joebass3 on
    F1nut Posts: 51,918
    Stick to the wood.
  • joebass3
    joebass3 Posts: 311
    A couple more pics with one cabinet finished. Note to self... make sure to put the roll of polyfill in FIRST before installing the wood braces!
    About the polyfill. I know it is suppose to be behind the tweeter and mid woofer, but when took the speakers apart the polyfill was rolled up very tightly and at the top of the cabinet. Basically it was mostly behind the tweeter. I rolled it up a little looser to fit behind the mw also.
    Also, is a 4"x4" piece of BH5 or sonic barrier still the go to size behind the MW?
  • I like the way the screws for the brace members are easily accessible for doing an A/B comparison. Did you glue the semi rings in yet?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • joebass3
    joebass3 Posts: 311
    Yeah I used a 2 part epoxy on the semi rings.
  • joebass3 wrote: »
    Bravo. You won't be disappointed.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,918
    Yes
  • joebass3
    joebass3 Posts: 311
    I built the braces for the other speaker today and decided to play around with the placement. It may not make much difference but, since the weakest spot of the cabinet seems to be the middle (between the MW and passive), I was able to get them closer together by about 3/4". I think I'll leave them there.
