replacement driver for LSi-C center speaker
I have a LSi-C speaker with a blown 5 1/4" midrange/driver. I have been trying to get a clear answer from Polk tech support as to if the same sized driver from one of the other speakers in that series (LSi-7 ,9, 15,25) would be compatible to swap out. They will simply say that they "don't recommend it", but I can 't get an answer as to why. The agent with whom I spoke was able to confirm that at least the models 7, 9 and C have the same model number of driver (was MW 5534, later RD 5534-1) I can find both of these model numbers for sale on E-bay, advertised as pulled from a LSi7 or 9. I need to know if there is any reason they would not be compatible. On a related note, Polk's tech support has gone off a cliff in the past decade. It has taken me several phone calls to get the limited information I now have. I appreciate any insight anyone can share.
Answers
    VR3 Posts: 29,524
    All the same drivers across the board to my knowledge
  • sgmsmg
    sgmsmg Posts: 556
    Are you sure the driver is bad. If I remember correctly it is common to suspect a bad driver on the LSi-C but one of the drivers is for lower frequencies so it sounds like it is not working. It does not output the same as the other driver. If you search on here you will find many instances of people suspecting a bad driver but that is how it normally functions. I know when I had the LSi-C I thought is was faulty as well.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    VR3 Posts: 29,524
    First gen lsic used a large single inductor for the bass driver that is known to melt, fwiw
  • timhj
    timhj Posts: 5
    sgmsmg: According to the Polk phone rep (for whatever that may be worth), I should hear the same thing coming out of both cones. I have heard elsewhere what you are describing. Tonight, I will swap the two, turn off all other speakers and see if I get the same result. I will also be able to see the part number and manufacture date. I will let you know what happens.
    VR3: Do you know when they changed the design away from the single inductor? If I have the older design, can you describe what I should look for to see if it is damaged?
    Thanks, both of you, for your help.
    pitdogg2 Posts: 27,215
    edited December 2022
    Take pictures of the XO board and backs of the speakers and post them, it will help.
  • timhj
    timhj Posts: 5
    pitdogg2: What is an XO board?
    crossover board, it will show the components
    VR3 Posts: 29,524
    I believe when they went to a painted finish versus vinyl the crossover was also updated
    F1nut Posts: 51,934
    That is incorrect.
    VR3 Posts: 29,524
    That is incorrect.
    Exactly, one woofer does almost all bass frequencies
  • timhj
    timhj Posts: 5
    Gents/ladies: In an effort to eliminate as many variables as possible, I decided to use a Bluray as a source material, whereas I first found this problem when watching Breaking Bad on Netflix. I'm glad I though to try this. I watched "Heat", using two scenes: the gang blowing the door off of the armored car and the climactic bank shoot-out. In both cases, I could see the left woofer moving, and to the extent I could hear such frequencies, I could hear it when I covered the right woofer and the tweeter with a pillow. I also varied the low cut-off frequency via the receiver, varying from 40HZ all the way to 200HZ, and sure enough, the left woofer performed differently as I varied it. I also watched the restaurant scene, which is all dialog and some background noise and it sounds fine. The bottom line is that I think the problem was crappy streaming audio. Upon concluding this, I didn't take the unit apart.
    sgmsmg: With all this said, it would seem that you are correct, that the two woofers handle different frequency ranges. This contradicts what the tech phone support said, but I am learning to not be surprised by that. Out of morbid curiosity alone, I will call tomorrow to pose the same question and see if I get a different answer. Thanks everyone, for your help.
    F1nut Posts: 51,934
    Understand that Polk CS isn't what it used to be. Most of it is outsourced and those folks are not the most knowledgeable. You received the correct answers here and discovered for yourself the info provided here was correct. There's no point in tying up the CS phone line tomorrow.
  • timhj
    timhj Posts: 5
    I have a couple final questions regarding he LSi series, for anyone who can take them. I also have LSI25s, LSi9s and LSi7s. I am guessing from the different specified frequency ranges and crossover frequencies between the model 9 and 7, that the model 9 is configured much like the LSiC, in that the two 5 1/4" drivers handle different frequency ranges, rather than both putting out the same. Secondly, I wonder if the LSi25, due to having a separate 10" woofer, has its two 5 1/4' drivers both putting out the same frequencies, unlike in the LSiC. Can anyone speak to these two? Thanks again.
    VR3 Posts: 29,524
    as far as I can remember ALL of the LSi MTM speakers have the cascaded array (one driver is oriented to bass)
