How to mount CSi5 and RTi6
Dannieboiz
Dannieboiz Posts: 242
Now that I mounted my plasma on the wall I want to mount my CSi5 above it and point it downward. I'd also want to put the RTi6 on the wall as wel.... How's everyone else doing this? Are there speaker brackets that fits the CSi5? I tried to look for some wall shelf but the available one won't fit and I'm too lazy to make a board out of scratch (I will if it's my only choice)
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • Willow
    Willow Posts: 11,233
    edited March 2005
    I saw some one use 2 or 3 L brackets and laid the centre on it
  • hexumjunkie
    hexumjunkie Posts: 191
    edited March 2005
    i wanna hang my csi1 on the way wish it had a bracket....i seen someuse a tv stand for it !
  • Dannieboiz
    edited March 2005
    just putting on top of the tv is almost the standard way of doing it. I have a plasma so I won't be able to put it there. I want to be able to tilt the speakers downward since it'll be way up there so L brakcet isn't an option
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • Willow
    edited March 2005
    How about L brackets underneath and flipping the center upside down
  • unc2701
    unc2701 Posts: 3,587
    edited March 2005
    flipping it upside down won't work- that'd point it at the ceiling... Does it have keyhole mounts on the back like the LSiC?
    Edit: I'm stupid... put it underneath& flip it upside down- good idea.
    Backburner:Krell KAV-300i
  • Dannieboiz
    edited March 2005
    nope no keyhole.... was told by polk never to drill into the power ports on the csi5 they're not made for mounting.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • unc2701
    edited March 2005
    Sounds like your going to have to be crafty...
    What I'd do:
    Go to home depot, get two pieces of Oak, one is a plank slightly larger than the footprint of the CSi by 3/4" thick, the second is 1.5" by 3/4" by the length of the CSi. Get sturdy hinges. Attach the thin board to the plank to give you a slight lip (1/8")and attach the hinges to the back. screw to the wall. Use wire and eye hooks to adjust the height/angle.
    cross section (you sit to the left of this, wall is on right):
    &nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbspSpeaker here
    ____
    |&nbsp&nbsp&nbsp&nbsp&nbsp|________________________
    |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp|wall here
    |&nbsp&nbsp&nbsp&nbsp&nbsp|________________________|
    |&nbsp&nbsp&nbsp&nbsp&nbsp|&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsphinge here
    |___|
  • Mjr7531
    Mjr7531 Posts: 856
    edited March 2005
    Well, What I think you could do if make a nearly flat shelf and maybe use the kickstand that comes with it? Worth a shot, otherwise, you'll end up with a wierd shelf mount.
  • Dannieboiz
    edited March 2005
    I tried the shelf option already and they didn't look to go... there are no bracket that looks half way decent to match with my components. It looks kinda off with a shelf above an expensive TV....
    I was browsing around and there are some small speaker swivel mounts for light weight bookshelf/sat. Perhaps I can use a pair (one on each side) That way I can tilt it anyway I want... what do you think of that idea?
    seems like the most common size are for 8lbs but if I use a pair or a treo of 10 lbs bracket then I should be good for the CSi5
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
  • okiepolkie
    okiepolkie Posts: 2,258
    edited March 2005
    Just knock a big hole in your wall, build a shelf and put the center channel to where it sticks out a couple of centimeters. Then you could put it at any angle want. Of course, this won't help your imaging(not to mention the boominess it will probably create from the rear ports), but it will look good.
    Hope you find something suitable.
    Zach
    Tschüss
    Zach
