I need your opinions on some subwoofers
glemay
Looking to buy a 12 inch subwoofer that will run off a Clarion amplifier putting out around 380Watts RMS. The sub will be used on our boat, so it will have to fill a fairly large area, but we are not shooting for mind boggling SPL, but SQ and loud enough listening levels. We want a subwoofer that will be able to withstand the elements, moisture, humidity, changing temperatures, exposure to sunlight.
What type of box should we go with, note: nothing really big. Do you guys think this will fulfill our needs?
Here are some subs I was looking at :
MTX
Infinity
Rockford
Rockford2
JBL
We don't really want to buy online. What other suggestions do you guys have?
Gerald
MTX
Infinity
Rockford
Rockford2
JBL
Gerald
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
never having done a marine project, this is just a guess, but i'd vote for a 15" sub, just to really fill out the bottom end, cause you're not going to get the cabin gain that a car will... heck, you're probably going to get less than a standard house setup. i know you said 12", but...
to withstand the rigors of being outdoors, you have to go with a car sub... if you can get one, a marine sub. to fit a small box, choose one with a loose suspension (ie one designed for a small box
). 'truck' subs could work well, they're very shallow.
go for metal and rubber parts... that means no foam surrounds, no paper-composite cones, nothing like that... they could disintegrate.
i can't seem to access any of those links, or i would comment on them.
this in this would probably do well.It's not good, very fundamentally simply not good. - geolemon
Hmmm, check out the MMC2124DVC and load it in a sealed box. It takes something like .88 cu. ft. which is dinky for a 12 inch sub. If you wire that Clarion amp to the sub in a 2 ohm load, IIRC, it should be putting out about 650-700 watts RMS. The MMC2124DVC has a 400 watt RMS power handling per voicecoil. I can also verify first hand that it will rattle fillings loose if you throw some power at it and that Clarion amp should be plenty of clean power for it. I pushed a JL Audio amp to clipping at Tweeter with a pair of MMC2124DVC's and I was throughly impressed with them. Defintly a better performer than anything you listed. They also go for around 150-170 bucks U.S.
I think it will perform better than you expectations. It'll stand up to the weather too with butyl rubber surrounds and the Dynamic Balance Metalized Poly Cones. Future Shop should beable to get it for you too. They are an authorized PA dealer.Expert Moron Extraordinaire
I second Jstas' recommendation. Those are awesome subs. Ill be going with a 10" version in just a matter of days (yippee)!
As mentioned Tweeter is about the only Polk/Momo retailer but you may not have on in your neighborhood.
I know you are leary of online ordering, I am myself, but iof you cant find a Tweeter or Future Shop, SoundDomain.com is a very trustworthy dealer. You cant find too many people that have much bad to say about them and Ive never heard of them ripping anybody off. Plus, they are an authorized Polk retailer so you know youre not getting some remanufactured crap and youll get the full Polk warranty which is among the best in the industry.polkaudio sound quality competitor since 2005
Thanks for all the suggestions.
I got a few more questions. What would be the advantage of going with a dual voice coil subwoofer and running it at 2 ohm. (I'm not sure if Clarion is stable down that low)
If I went with that polk you suggested Jstas, I should be able to buy a box that will work with that sub right? I think I would be really interested in the polks if Future Shop can get them.
A 15 would be nice, but don't think we would have room, but if we did, would a 15 really be better than a 12. Would it sound as clean?
By going with a sealed box would we lose much spl and the frequence range?
GeraldMain System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
Got a model number on the Clarion?
You can buy a box that should work out just fine with that sub. Most pre-made boxes will be right around that .88 cu. ft. displacement you are looking for. Most are .80-.85 and if you just stuff it with polyfil, it'll work out well enough.
A 15 will not be better than a 12. You are talking a negligible difference. The only benefit a 15 would have over the 12 is volume. It'll get slightly louder. Problem is that it's sensitivity usually decreases so it needs more power to belt out the tunes than the 12 will. The 12 is a smaller cone so it is more responsive than the 15. The 15 may or may not dig a bit deeper in the frequency range than the 12 but if so, it's only 2-3 Hz at the most. If you had dual 15's vs. dual 12's, the difference would be more noticable. For a boat, the 12 will do fine. You don't need anything more.
A sealed box can be just as loud as a ported box. I'm recommending a sealed box because a ported box would be lost out on open water. A ported box needs a cabin to pressurize to give that louder bass. A sealed box doesn't necessarily need that cabin. Also, a sealed box setup will dig deeper in teh frequency range and be much more accurate. Typically a sealed box will have a flatter response with a wider frequency response than a ported box. It's a better choice than ported for a boat. It will also not let water and other crap into the port. Ported enclosures are not all that weather tight what with a big hole in them. Sealed will be much less likely to sustain damage from the elements. If you are worried about volume, that Clarion should have plenty of balls to push that sub at it's limit. At that point, ported vs. sealed, SPL is a moot point. Either enclosure would reach levels that would be uncomfortable for your average listener. Don't worry about it. Sealed is a better choice for many reasons.
Let us know what model that Clarion amp is so I can dig up some info on it. I'm pretty sure it's 2 ohm stable. Damn near everything made in the past 6-8 years is 2 ohm stable.Expert Moron Extraordinaire
apx400.2m I believe. It is a marine amplifier.Main System:
Second System:
Well that's a drag. Your amp is only 2 ohm stable in stereo mode. I thought you had a mono sub amp. Not that big of a problem. You can get a single voice coil MMC2124 and still get good performace out of a similar enclosure. Granted volume will not be what it could be with DVC but it will make plenty of noise for you.
Then again an amp that only puts out 100W x 2 at 4 ohms is not necessarily going to be a bass power house. If you have the funds, you might want to consider upgrading that amp to probably about twice that power at the minimum.
If you can't though, those MMC2124's are certainly performers and don't serve to dissappoint. Either one, the single or teh dual voice coil models, will serve you well and meet your expectations if they don't exceed it.Expert Moron Extraordinaire
Well it would be nice if we could get a bigger amplifer but my dad is ok with the idea because we already have an amplifier laying around not doing anything, so we are already part way there.
So if I understand this correctly the dual voice coils allow for more volume.
Does anyone have any experience with the MMC2124 in a sealed box?
GeraldMain System:
Second System:
Yes, I do. I already said that I do. The DVC doesn't sound any different than the MMC2124 non-DVC. The DVC sub just plays loud because it has twice as many voicecoils and handles twice as much power. The whole reason I was thinking DVC in the first place was because of the lack of cabin gain on a boat. You obviously are on a budget and the MMC2124DVC runs about $170 and will play loud yet still fit in a small enclosure. Space is at a premium on a boat so that sub fit your requirments of loud enough to hear, small enough to fit and cheap enough to not break the budget.
You can still get the DVC and run each voicecoil at the 100 watts RMS off of the stereo amp but it will only have about 1/3rd of it's rated RMS power. The problem there is that you are going to need to play it at high volume when out on the water because of that lack of cabin gain. That loud volume will make that sub start to push harder and it's impedance will change. As it changes, that sub will need more power from that amp that just isn't there. That causes clipping which kills amps and subs. You'll have wasted all your money and time and have a dead amp and sub to boot.
Go with the MMC2124 and bridge your amp to a mono mode at 4 ohms. It will run about 200 watts RMS which is roughly half of what the MMC2124 needs and creates a much better situation for you.Expert Moron Extraordinaire
now, now, we don't want to sound too optimistic and happy around here...Originally posted by Jstas
That causes clipping which kills amps and subs. You'll have wasted all your money and time and have a dead amp and sub to boot.It's not good, very fundamentally simply not good. - geolemon
Thanks Jstas, and sorry if I misread some where. If it is not possible for us to get Future Shop to order that Polk Sub, which of the 5 subs I first mentioned would be a close second?
GeraldMain System:
Second System:
Honestly, I'd take that JBL. It'll work great with the amp you have and is probably the best bang for the buck out there. I see the $119 price and think it's kinda high but that Canadian currency price so it's right about where it should be price-wise. It's a highly under-rated sub. Great sound, hard hitting and fairly good looks. Works well in almost any enclosure. I've used them before, infact I still have a 10 inch sub that is about 6 years old and it still works like it did 6 years ago. Defintly not a bad buy in any respect. It's also very forgiving of box size. They recommend a optimum box size but they don't seem to be bothered by sizes that are as much as 30% bigger or smaller than the recommended size. They dig relativly deeply (down to the mid 20 Hz range) and have a high sensitivity at 93 dB for a sub.Expert Moron Extraordinaire
Depending on the cost and possibilty of getting it at Future Shop we might go with the JBL. Here are some of the boxes for 12 inch subs that I have access to, which would you recommend:
Basswork Sealed
Basswork Ported
Q-Logic
Extreme Bass
Basswork Slot Ported
Gerald
Main System:
Second System:
I don't have too much experience with Bassworks but Q-Logic makes a decent enough product. It all depends on two things, doe sit meet the requirements of the sub sufficiently and does it meet your needs?
If so then price is the factor. Whichever one you feel is worth your money, thats what you buy.
What you might want to do for a marine application and it'll give you som egood experience is to get yourself a sheet of MDF, build a box to similar dimensions of one of those Q-Logic boxes and then cover it in a layer or two of fiberglas. Let it cure, sealed the insides with silicone caulking in the joints and then paint it with a good quality marine paint. It'll match your board and there will be no carpeting to get all funky. Plus, water is a non-issue because the fiberglass will effectivly waterproof and seal the enclosure. It's easy and fairly cheap and will be a damn sight better than the pre-fab boxes.
To 'gals the box after it is built, cover it with resin (make sure you haven't mounted subs or terminal cups yet) and then gran sheets of the woven fiberglas, soak them in the resin and lay them over the box coating it completely. Cover with another layer or resin and let it dry for a while. Come back repeat the steps for a second coat. Not only will it add strength but it will also hide any imperfections in your craftsmanship of the box. Trim off edges and cut holes if you didn't already, just like you would with any piece of wood.
For the 'glas, you should get a marine grade resin because water can cause the fiberglas to deteriorate. Especially saltwater. Same thing for the paint, marine grade. Also, grab yourself some gasket material at a boat shop and make yourself some gaskets to go around the speaker hole and the terminal cup hol to reall seal it from the elements. Get a terminal cup with gold connectors so they don't corrode and use stainless steel screws too. Even if they sub comes with screws, get stainless steel ones.
That should give you a sub enclosure that will last a good long time, be strong as hell, weather resistant and leak-proof.
Like I said before though, a ported box would be a bad idea on a boat.Expert Moron Extraordinaire
Thanks Jstas,
Now to run this by my dad. We will probably be going with the JBL since I just noticed the Polk MMC2124 retails for about $250 CDN and we can pick up the JBL for about half. And looks like sealed is the way to go. Not sure weather we will buy or build, although a fiberglass box would be nice, real nice.
Well thanks again!
GeraldMain System:
Second System:
check this out will tromp all. http://www.ascendantaudio.com/Atlas%2012.htm
looks nice, i like the xbl motor, but it's a paper cone, not really the best choice for a marine application. other than that, i'd say it's a reasonable option.It's not good, very fundamentally simply not good. - geolemon
Yeah, what neomagus00 said, plus it looks like the surrounds are foam, but not sure.Main System:
Second System:
all of the subwoofers with XBL^2 technology that i know of have foam surrounds
hum... wonder why that is? butyl rubber too stiff, perhaps?It's not good, very fundamentally simply not good. - geolemon
if i had to say, i would say 1 for sound quality, and 2 because maybe theyre better for longer excursion subs??
i dont know, ill ask
yes it is foam they are great i have 4 now yeah i just need to get some stuff to make a box.
Well today we went to Best Buy. My dad and I check out the JBL's and didn't really seem too impressed with what we saw or heard. I mean it wasn't bad, just not quite what we were looking for. So we then left Best Buy and called up a friend and he recommended this place. So off we go.
We get there and walk into the place and tell the guy we are looking for a subwoofer to put on our boat. He showed us a subwoofer in a nice ported box with a grill. We liked what we saw and heard and walked out of the place with one of these.
Got it home and mounted the driver in the ported box and went off to the boat. I hooked the subwoofer up temporarily and was pretty happy but have yet to hook everything up and see what it really sounds like. But I think we will be happy, it's a real smooth sounding subwoofer. And not to mention the price, all for about $250 CDN.
GeraldMain System:
Second System:
Thats cool. If you like it and are happy then that all that matters.polkaudio sound quality competitor since 2005
Just finished applying a coat of sealer/clearcoat/varnish or whatever else you want to call it to the exposed MDF to prevent some of the moiture from penetrating.
GeraldMain System:
Second System:
With the decent weather today, we installed the Clarion APX400.2M amplifier down in the cabin and tied it into the breaker panel. So to turn on the sub all we gotta do is turn the Brigde Stereo breaker on.
I then got everything hooked up to the receiver and turned it on and adjusted my gains and let me tell you, my dad and I were very impressed.
Everything sounds so much cleaner than before and we now have so low end in our music. I honestly must say that the Pioneer Premier in a ported box hooked up to our Clarion amplifier sounds pretty similar to my Paradigm PW-2200. It is not as refined, but isn't too far away. And I'd say the Pioneer Premier could hit similar SPL to the Paradigm even with very minimal room/cabin gain but won't sound quite as clean
Very, very happy with our purchase. Everything sounds great, the subwoofer is built very well, very durable and everything looks great. I'm going to have one hell of a summer. Can't wait!
Thanks again guys for all your input!
If anyone is looking for a very well built subwoofer that has exceptional sound quality for a reasonable price, check out the Pioneer Premier TS-W125C. Great subwoofer all around!
GeraldMain System:
Second System:
glad you like it! thats the main thing in car audio
i wish i was easily satisfied:(
LOL!!!
Hey Cody, that reminds me; isnt it time for you to buy new speakers again?
not quite:D
im almost done, i can see the light at the end of the tunnel...
all i need now is sound deadening, amps, rcas, power wire, couple batcaps, alternator, equalizer, random distroblocks, and battery terminals
yea, almost done;)
And what about the new truck too?
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
