I completely changed my mind about the Polk RTA 15TL. They're not very good.
245
  • skipshot12
    skipshot12 Posts: 1,837
    That Denon receiver is neither of those two,
    Powerful or high-end.
    treitz3 Posts: 19,952
    Hello, @bcwsrt and please allow me to offer you a very warm welcome to the Polk forum.
    The OP can learn from you... ;)
    audioluvr Posts: 5,882
    I have a Denon AVR-985 I use in my TV room. It works for making sound come out of the speakers. I used to enjoy watching concerts on PBS etc. When I had my B&K AVR-507 but now not so much. I need to upgrade but no funds right now.
    msg Posts: 10,452
    audioluvr wrote: »
    What about the extra income from that serial killer you were renting the barn to?
  • skrol
    skrol Posts: 3,437
    edited November 2022
    I played with a few Denon receivers and my RTA-11TL's. A 2ch DRA-825R was ok but it was night and day when I upgraded to a DRA-835R. They have basically the same wattage rating but the DRA-835R drives more current and is more of a dual-mono design. Imaging improved but mostly the bass was much better controlled. I tried a Denon AVR-888 and it sounded like ****. Presently they are servicn HT duty and my Marantz SR-7010 drives them nicely and sounds pretty sweet. The best was my Parasound HCA-1000A, which is now driving my LSi15's. A clean, high current amp will serve to clean up the bass.
    The RTA-15TL with the rear firing PR is more finicky about placement than the RTA-11TL. I have placement issues with the LSi15. Too close to the walls and they get boomy and muddy. Depending on placement, you can love them or hate them.
    Fix these issues first before you decide on ditching the RTA-15TL. If that is not possible then you probably should look for a more forgiving speaker.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • stevep
    stevep Posts: 358
    15TL wrote: »
    I paid $200 for them used like new.
    If you're anywhere near Denver I'll give you $200 for them and it won't be a failed experiment anymore.
  • bcwsrt
    bcwsrt Posts: 2,380
    treitz3 wrote: »
    Thank you, Tom, for the kind words. Much appreciated. However, it seems the OP is unfortunately having a hard time learning from the OGs here, so it is unlikely I will have any success either. 🤷‍♂️
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
  • la2vegas
    la2vegas Posts: 764
    bcwsrt wrote: »
    treitz3 wrote: »
    Sorry but I must correct you. Yes, there are some old guys here but OG's, never.
  • bcwsrt
    bcwsrt Posts: 2,380
    la2vegas wrote: »
    bcwsrt wrote: »
    treitz3 wrote: »
    Well, I believe I know where you are coming from, but at the same time, I believe you know where I was, too! 😝👍
    Brian
  • Nightfall
    Nightfall Posts: 10,084
    la2vegas wrote: »
    bcwsrt wrote: »
    treitz3 wrote: »
    It's a turn of phrase dude.
    afterburnt wrote: »
    Village Idiot of Club Polk
    nooshinjohn Posts: 25,887
    Nightfall wrote: »
    la2vegas wrote: »
    bcwsrt wrote: »
    treitz3 wrote: »
    He's a Raiders fan... can't expect much in the way of intelligent thought out of him.
    Either listen to the folks that are coaching you in the right direction or stop bashing something you obviously do not know anything about. It's unbecoming and a waste of our time.
    You obviously have much to learn.
    15TL wrote: »
    la2vegas wrote: »
    bcwsrt wrote: »
    treitz3 wrote: »
    You guys are also desperate to fit in. Starving for acceptance, maybe I'll go buy a record player so I can be one of you.
    Here is a vast selection for someone of your experience...
    https://www.etsy.com/market/fisher_price_turntables
    Come back when you grow up.
    pitdogg2 Posts: 26,957
    Stop feeding the troll.
    Unless we all agree to his narcissistic values he's not here to do anything but argue with anything that we have to say.
    According to him:
    All of us here are hipsters
    All of us here listen to vinyl
    All of us here are desperate to fit in
    Polk makes poorly designed speakers
  • skrol
    skrol Posts: 3,437
    Denon AVR-3808ci
    Front:
    130 W + 130 W (8 Ω/ohms, 20 Hz ~ 20 kHz with 0.05 % T.H.D.)
    160 W + 160 W (6 Ω/ohms, 1 kHz with 0.7 % T.H.D.)
    Denon specifies 6 to 16 ohm speaker for 2ch
    8 to 16 ohms for surround.
    My 2Ch Denon receivers were close in rated power.
    DRA-825R was 90W into 8 ohms
    DRA-835R is 100W into 8 ohms
    The 10W is negligible but the DRA-835R can drive more current and likely has a better damping factor than the 825R. It was basically Denon's near top of the line integrated amp with a tuner added. This resulted in a big improvement in sound with my RTA-11TL. Now I wouldn't bother trying to drive my LSi15 with either Denon receiver. They are power hungry and their dynamic impedance drops way too low.
    While the RTA's are rated 8 ohm "compatible", their dynamic impedance over the frequency range may dip much lower.
    For many years I thought my DRA-825R was awesome. Many folks told me I could do much better. I didn't listen until I tried. I am the same way about things like cables and power conditioners and other stuff too. I try sometime and I learn. There is much to this stuff.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skipshot12
    15TL wrote: »
    la2vegas wrote: »
    bcwsrt wrote: »
    treitz3 wrote: »
    Wow, is this person 12 years old?
    Nothing constructive here…
    Me thinks it’s time to get to steppin, move on dude.
  • machone
    machone Posts: 1,552
    According to him:
    Yep, we get one of these every year.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • skipshot12
    I don’t know what a troll is and I don’t get it.
  • bcwsrt
    bcwsrt Posts: 2,380
    15TL wrote: »
    15TL wrote: »
    I bought them for $50 so I probably would if we were close.
    Well, there is something obviously wrong here. Lol
    Brian
  • invalid
    invalid Posts: 1,446
    15TL wrote: »
    gmcman wrote: »
    invalid wrote: »
    I can't believe you think that avr has enough power to make them sound good, that's the reason the bass doesn't sound right.
    My thoughts exactly. The power of the Denon while looks good on paper, mixed with old crossover components, won't deliver the goods
    It's not the watts, but the amps...amps as in current
    It has more than enough power. Maybe crossovers are contributing but it is not lack of power. I think they are just old poorly designed speakers.
    You really don't know much do you, I can use a 50 watt krell amp that would drive them way better than that Denon you are using.
  • Nightfall
    bcwsrt wrote: »
    15TL wrote: »
    15TL wrote: »
    I told you I doubt anything he says 😂 He's just trolling. I bet he's got pencil arms.
    afterburnt wrote: »
    Toolfan66 Posts: 17,994
    I am guessing this cat has been here before under a different name, and has trolled here before, more than likely he was banned from here.
    Why else would one come in here and troll the place over some 15tl’s?
    bcwsrt wrote: »
    15TL wrote: »
    15TL wrote: »
    You'll fit right in here!
    We all know what this picture says..
    msg Posts: 10,452
    According to him:
    You forgot to add that Monitor 70 Series II cost $600 and beat the 15TLs.
  • Nex
    Nex Posts: 36
    Well, I'm not going to tell you what you are supposed to like.
