Carver silver 7T amps
faster100
I found a pair for 1100, good deal?? or to much..
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
President of Club Polk -
Whoa! Those are sweet looking. What happened to your Dyna?
Maurice -
Those things look like they could kick your tail man...jeez...
Awesome looking - I'd pick them up...just to look at...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If their 575 watt amps, that's under a dollar a watt, and that's the price ratio I like to buy at or below.
George Grand (of the Jersey Grands) -
They arent mine, I was just checking as i found some myself for that price.. and was curious their worth...
Thanks GuysMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
They will do 900 watts into 4 ohms or 1000 watts into 2 ohms. Very clean and powerful sounding. When those meters jump up the lights go down.
One down side, they use monster cable inside...
Can you use Mono's on the SDA's with the cable?
PaulyLife without music would♭ -
They will do a crap load of power output, But are these up there with parasound and higher end amps qaulity? Plus you cant run these on sda 1b's Huh?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Pauly
Depends which cable. If it is pin/blade then yes you can use mono's with the AI-1 interconnect. Some mono blocks can be common grounded with a wire between each negative posts, you have to check with the manufacturer.
If you Blade/Blade then no mono blocks or non-common ground amps.
RT1 -
I have blade blade,
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Hold the press...
My 1C's have Pin Blade and i was asking around few months back if i could run 2 Carver M1.0 in Mono wiht the IC.
So can i or they have to be Truly Mono Blocks?
1100 isn't a bad price for them.
As far as being in the same class as parasound...etc etc. I would say they are.
so troy, do you use your silver 7's on your sda's? and if so , How?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I have used my Silver 9t's on my 2.3tl's from time to time as I have 'borrowed' an A1 interface cable, however, generally, I use the monos on my Carver Amazing rigs.
I have a Carver TFM-45 that has plenty of power for my SDA's.
Ok cool, was wondering about the whole common ground amp thing and sda's..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I have used mine with the standard cable with no problems but do so at your own risk. I bought the transformers but never put them together.
what sda's do you have maxMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I have many.
But the ones I used with the carvers were the SDA-SRS blade blade combo. I bought some transformers for the 1.2's I have (just to be safer with the mono-blocks) but never made them.
There are different types of mono blocks here. Some are set up like a bridged stereo amp while others are just like a single non-bridged channel. The bridged stereo amp type MUST be isolated with the transformer. It is my belief that the carvers are not the bridged style and therefore can be used with the standard interconnect. You take your chances though because if you (me in this case) are wrong it can get real expensive.
Worse case scenerio what would happen (what would get fried)?
ah just your amp, and possibly the tweeters maybe? they would know better then me, however i think like max said... its a take a chance thing that no one really knows the answer to, unless it happens to them... not many dare to test the theoryMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
It would pulll a lot of power from your amp and eventually kill it. The reason is that the negative speaker terminal of a bridged amp is not necessairly at ground potential like a non-bridged one. If you can hook a ground between the two amps without harm then you can use any sda with it.
max,
So did you jumper the negatives of your 7t's together?
faster,
$1100 looks to be about the median ebay price for the eleven auctions I've saved. Low I have record of was $750 (a BIN auction); high was just set at $1375.
If they are cosmetically nice, $1100 is fair. Many are nicked as they are usually set on the floor.
A pair of 9t's go around $200 higher.More later,
Tour...
Vox Copuli
My negatives were left floating. Actually I have the 9T's but from my understanding there are only a few resistor value differences.
I was going to ask what the differences in the 7's and 9's were that would merit such an price difference.
Same reason it's better to have a pre-amp that "goes to 11"?More later,
Tour...
Vox Copuli
