Magnet shift prevention
In searching the forums I found a ton of info on repairing shifted magnets on Monitors (7B w/Peerless tweeters in my case), but few on preventative measures.
My Monitor 7B magnets have not shifted and I'd like to make sure they never do. What is your best suggestion on how to achieve this?
    F1nut Posts: 51,664
    There's plenty of info here on gluing the magnets to prevent shifting.
    txcoastal1 Posts: 13,499
  • StantonZ
    StantonZ Posts: 452
    edited October 2022
    If there was ever an example of "an ounce of prevention is worth a pound of cure"...gluing (good) magnets is it. I did all 8 of my drivers (4 speakers) last year before we moved.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • skipshot12
    skipshot12 Posts: 1,772
    Can anyone help me find something on magnet glues?
    Saw where someone referenced lawdogg did some destructive testing.
    Tried searching lawdogg and could not find it.
    I think it would be a good read on his findings but zero luck so far finding this.
    Thanks y’all,
    Skip
  • skipshot12
    Jesse,
    Might you know where I can find this?
    F1nut Posts: 51,664
    Nope.
    Just use JB Weld and sleep well.
  • skipshot12
    ^ Already done with mine. JB Weld.
    Thanks, was just wanting to read his findings.
