Monitor 4 Series bookshelf speaker identification crossover upgrade
HI, I am new to this forum. My son gave me a pair of Monitor Series 4 speakers. I'm trying to identify exactly what model (4, 4a 4s) they are and when they were manufactured (pictures attached). I've read about the various models of this speaker on this forum. The label only says Model 4. They sound OK, but because of their age I was thinking about replacing the crossover. I've never done anything like this before but I am interested in taking on the project. I have also attached a crossover schematic for a 4a speaker which I found online. I would appreciate any advice on identifying the speaker and replacing the crossovers. Thanks.
    pitdogg2 Posts: 27,317
    No picture came through. Please post a front pcture if only posting one. That should be pretty straight forward. I belive they have one cap and resistor in each;
  • skrol
    skrol Posts: 3,462
    edited October 2022
    An actual picture would be most helpful but ... from the info I have:
    The original Monitor 4 had a dome tweeter either Peerless (black dome) or the SL-1000 and neither had the acoustic lens over the tweeter.
    The Monitor 4A had the tweeter with a 3 legged acoustic lens. The cabinet was 14.5" high.
    The Monitor 4 Series 2 had the SL1500 tweeter with 2 legged acoustic lens. The cabinet was 14.25" high.qoa5suw0tc16.jpg
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • irvman
    irvman Posts: 6
    Thanks for the replies. Sorry images didn't come through. After looking at the posted images, I clearly have a Model 4A. Was that an official model number, because the label on the rear my speakers shows no "A" after the 4. I am resending the schematic of the crossover that I found.
    F1nut Posts: 52,000
    edited October 2022
    irvman wrote: »
    Yep. https://www.hifiengine.com/manual_library/polk-audio/monitor-4a.shtml
    That is not the schematic for your speakers. Just pull the crossover, all the values will be printed on the components.
  • skrol
    skrol Posts: 3,462
    I believe sometimes Polk used old labels on early release model changes to use them up.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • irvman
    irvman Posts: 6
    I've seen 3 model numbers for these speakers 4, 4a 4.5. Are the drivers and crossovers different in each model? If the crossover in my speakers do not match the schematic for the 4A that I sent, then I assume that my model maybe a 4.5. I wish Polk had been better matching changes with the model numbers. From the link you sent me, I guess my speakers are 6 ohm with 91db sensitivity. They should be easy to drive with my Marantz 2215B receiver which only has 15 watt/channel.
  • skrol
    skrol Posts: 3,462
    The Monitor 4.5 looks similar to the 4A but the cabinet is bigger, measuring 17x9x9. There was also a Monitor 4.6 in the early 90's that used the SL-2500 dome tweeter and measures 17x8.5x10.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • irvman
    irvman Posts: 6
    My 4's are 14 inches high so they are definitely not 4.6's, so I assume they are 4As (see picture). I tried to remove the input plate to check out the crossover, but I couldn't get it out of the cabinet more than 1/4 inch even with gentle prying, and I didn't want to force it. Any advice of getting this out of the cabinet?
    As mentioned by some others, these speakers sound bright with not much bass. But, I don't have expensive equipment and I don't have "audiophile ears," so maybe I should not be commentlng on how
    they sound.
  • irvman
    irvman Posts: 6
    Please check out the Monitor 4 speaker picture in my previous post. Someone on AudioKarma said that the woofer and tweeter are not the original components. I would like to have this verified if possible or let me know how I can verify this. Fortunately, the speakers didn't cost me anything. My son left them with me when he moved. He obtained them from a friend. Thanks.
  • Gardenstater
    Gardenstater Posts: 4,803
    edited October 2022
    I agree with the person on AK. The MW is without a doubt not original. Bears no resemblance. Tweeter looks different from the tweeters that Skrol posted and is a bit too small for the cutout.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 52,000
    As I mentioned to you on AK, that's not the original tweeter or mid-driver.
    They are not worth putting any money into.
  • irvman
    irvman Posts: 6
    Thanks all for your input. I will let my son know.
  • Hello! I replaced the sl2000 tweeters in my 10bs with the Polk-recommended replacement, and was now wondering if I can use the old tweeters (nothing wrong) to replace the tri-strut tweeters in my 4/4.5s. I know they will need to be differently mounted— thoughts?
  • SoyalOvi wrote: »
    Highly doubtful because that tweeter is a 4 ohm impedance and the SL2000 is 8 ohms.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,408
    I don't know George, it might help the SL2000 loosing half it's frequencies.
  • SoyalOvi wrote: »
    Thanks for the insight
  • Long shot— anyone aware of a suitable replacement/ upgrade for that tri-strut tweeter?
  • SoyalOvi wrote: »
    I have no idea if it would have similar sensitivity but there are definitely 4 ohm impedance Peerless for sale quite often on eBay. M&K used them.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • This is probably the exact same as what you have, if you have a bad one:
    https://www.ebay.com/itm/197362195274
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Right on. Don’t have a bad one, just wanted to upgrade.
  • @SoyalOvi These 4 ohm ones came up in my saved search. https://www.ebay.com/itm/267528996232
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Thanks, man! I’ll check them out
