12/13v SBOOSTER BOTW P&P ECO MKII POWER SUPPLY
VR3
Max 3amps
Excellent power supply, comes with a variety of connector ends to accommodate many devices.
Was using on a router hub but rearranged some things to where I didn't need this power supply anymore.
$420 new
$300 f/f for polkie shipped conus
Max 3amps
$420 new
I had one on my lumin d1. Very good power supply for the$. I probably should have kept mine when I sold the D1. What are the barrel sizes on the connectors? I think i might want to try it on my deco 6E router.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Definitely a good power supply
Yellow: DC tip 2.5 x 0.7 x 9mm
Pink: DC tip 3.5 x 1.35 x 9.5mm
Black: DC tip 4.0 x 1.35 x 10mm (oa Asus plug)
Yellow: DC tip 4.0 x 1.7 x 10mm
Black: DC tip 5.0 x 3.0 x 10mm (HP plug)
Yellow: DC tip 5.5 x 2.1 x 11mm
Black: DC tip 5.5 x 2.5 x 11mm
Green: DC tip 6.3 x 3.0 x 11mm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks i have to DJ from 1 pm to 2 am for a Cancer charity gig. I will check what the tp link Deco 60 6E has on it tomorrow. I think one of them should fit and it should have enough amperage but, I need to double check.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Looks like it should be good, I've never seen anyone concerned with the length
That's what she didn't say
Mine is the 6E so i hope it's the same as what you are showing. I will shoot you a pmKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Sold!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
This is going to be interesting. I already have a EtherRegen going between the Deco 6E and my Innuos that is supposed to clean things up. I wonder how much of a difference I will hear? Nice little experiment to see how much more I can get out of the Ethernet side of things and what my 54 year old DJ ears can still hear or not hear LOL. I can use this on other things if I don't hear a difference so either way it will get used.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
