Seeking Advice
jbreezy5
Rescued these Focal 705v from a pawn shop, but the vinyl wrap on front left edge of each speaker is peeling back, but not quite enough to get under it with some wood glue.
It also seems like even if it was, the vinyl wrap wouldn’t quite fully cover the MDF.
Any suggestions on how to get these looking good again?
I had a similar situation with my HT surrounds. Great suggestion from Jesse got me fixed up here:
https://forum.polkaudio.com/discussion/188428/vinyl-veneer-pealing-anyone-have-a-fix“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
So I left the speakers in my truck one night intending to do a trade at a resell it place next day; however, I waited longer than intended, and heat in the vehicle pulled the vinyl back further.
I took a hairdryer to them for the “sleeveless” look. 😄
Thinking they might look cool if I use dark purple metal flake paint on the sides.
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
The cabinets look good. What about using a real wood veneer on them, or painting them a very high gloss piano-type finish with automotive paint?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »The cabinets look good. What about using a real wood veneer on them, or painting them a very high gloss piano-type finish with automotive paint?
Those could both be good options. Will have to do some thinking…
The prep for paint on MDF is a project pending paint type and your skill. Fortunately is a relatively small project space. If you like the sound enough to invest a couple hundy's then yes invest.
My advice if you ever decide to sell. Choose a basic finish.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Ron, isn't there a cat down in your neck of the woods that does veneer - like, real wood veneer?
Jim so and so... (I can't pull his name out of my head right now....)
Shat....been awhile, but not worth the shipping. J's gotta DIY or local2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Try the other end........
For those curious where I got the idea for purple metal flake paint…
Fun concept, and I get it.
They are yours for probably cheap ...all about your dime and if you like them.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Leather would be a nice look too. A high end Ferrari shop could do something really cool on those. Do palomino leather on the baffle and Rosso Corso for the cabinets...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Jay
They forgot to do the tweeters. Must've been a work in progress.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
nooshinjohn wrote: »Leather would be a nice look too. A high end Ferrari shop could do something really cool on those. Do palomino leather on the baffle and Rosso Corso for the cabinets...
Maybe if I get ahold of some Sopras, or above.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Another thing about the metal flake concept is the metal plate of the tweeter, texture of the midrange cone, and port all seem to kind of have this going on. Seems like this feature on the outer side panels might tie-in nicely with this.
Think I'm still leaning in the direction of my original idea.
It sounds like I will have to learn a bit about painting MDF, per @txcoastal1. Skill level zero.
Rather liked this paint job...
The artist might have taken the color inspiration from Focal Kanta speakers in the Gaulois Blue color. $15K a pair seems about right.
The Jackson Pollard on acid look! Good choice!Gustard X26 Pro DAC
