Are There Replacement Parts
I Was Fixing A Speaker But My 5-year-Old Son Broke Off The Bass Adjustment Please Find Me A Replacement
Best Answer
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,293
    Answer ✓
    Thanks for the photos. The best way to repair that kind of damage would be to epoxy the broken piece back to the main circuit board. Then repair the individual traces with wires linking the components to where they connected to the main circuit board.
    The other approach would be to find another AMR130 system as a donor and exchange boards. Polk definitely doesn't have any parts remaining for that system. The original procedure was not to repair them but simply replace complete units that became defective. Once the replacement supply ran out there wasn't anything left.
Answers
    Viking64 Posts: 7,600
    A replacement for your son?
  • verb
    verb Posts: 10,176
    Need more details !!! Welcome to CP btw!
  • Are your referring to a part on your AMR130 system? If so, there are no parts available for that model.
  • So What Broke Off Was To Turn On The Speakers And Turn Up The Bass Is What He Broke Off
  • SeleniumFalcon I Need A New Part That Adjusts The Bass And Turn On The Speakers
  • Are you referring to the knob that goes on the bass control? Or, did the shaft of the bass control get broken?
    Can you take a photograph of the problem?
