Are There Replacement Parts
OldLinuxDistros
I Was Fixing A Speaker But My 5-year-Old Son Broke Off The Bass Adjustment Please Find Me A Replacement
Best Answer
Thanks for the photos. The best way to repair that kind of damage would be to epoxy the broken piece back to the main circuit board. Then repair the individual traces with wires linking the components to where they connected to the main circuit board.
The other approach would be to find another AMR130 system as a donor and exchange boards. Polk definitely doesn't have any parts remaining for that system. The original procedure was not to repair them but simply replace complete units that became defective. Once the replacement supply ran out there wasn't anything left.
Answers
A replacement for your son?
Need more details !!! Welcome to CP btw!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Are your referring to a part on your AMR130 system? If so, there are no parts available for that model.
So What Broke Off Was To Turn On The Speakers And Turn Up The Bass Is What He Broke Off
SeleniumFalcon I Need A New Part That Adjusts The Bass And Turn On The Speakers
Are you referring to the knob that goes on the bass control? Or, did the shaft of the bass control get broken?
Can you take a photograph of the problem? -
