New Sunroom at Verb's House!
24
    VR3 Posts: 29,554
    That's awesome right there
    Clipdat Posts: 13,100
    My what a large beam you have.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    American Steel, fabbed and installed by Nelson Ironworks, Detroit MI!
  • verb
    verb Posts: 10,176
    Beam and endposts now all roughed in ready for drywall.
    Existing window framed up to now be a pass through to the living room.
    VR3 Posts: 29,554
    Looks like you inadvertently repaired a leaking window judging by that mold growth
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    Good eye! Yes we did! Existing windows are, not great, so eventually we're going to replace all/most of em!
    nooshinjohn Posts: 26,002
    Clipdat wrote: »
    He will be beaming with Verb Pride when this is all done…
  • halo71
    halo71 Posts: 4,638
    verb wrote: »
    Clipdat wrote: »
    Like the progress ya making there. But whomever did those welds must be new at welding. Severe undercut!
    --Gary--
  • Jstas
    Jstas Posts: 14,996
    halo71 wrote: »
    verb wrote: »
    Clipdat wrote: »
    Glad I'm not the only one who noticed, I didn't want to say anything and get called out as a know-it-all again.
    That crack in the base plate is a bit concerning too.
    Expert Moron Extraordinaire
  • Coming along and looking great.
  • DaveHo
    DaveHo Posts: 3,583
    edited August 2022
    Might have missed it, does the crawlspace have a poured floor? Do the footers have drain tile leading to the sump? If so, I'd treat it like any other basement space in your geographic location Other than a lesser volume than a typical basement of the same square footage, I don't see a difference. Run a dehumidifier with it set to a max of 50% RH and I think you'll be fine.
  • mrloren
    mrloren Posts: 2,474
    nice :)
  • verb
    verb Posts: 10,176
    DaveHo wrote: »
    Yep - Poured floor, with a sump field all around. I opted for a sump pump too, just in case, despite my builder saying it's not needed since we're on a hill, but I went with one anyways.
  • verb
    verb Posts: 10,176
    anonymouse wrote: »
    That looks like a pretty large room. What are the interior dimensions?
    approx 21' wide x 24" deep
    Toolfan66 Posts: 18,189
    Those welds are horrible.
    txcoastal1 Posts: 13,519
    Toolfan66 wrote: »
    What would you know :p
  • verb
    verb Posts: 10,176
    Some updates.
    Framing around my ugly beam complete! The wall underneath will be removed and opened up to the rest of the house. No post required. Also the existing window on the left will be removed and converted to a walk through to the living room.
    Windows have been delivered after a 6 week delay. Waiting now for some concrete work (below) and grade leveling around the addition before they can be safely installed.
    Retaining walls and entry ramp for the crawlspace under construction. Footers done with rebar tie in to the walls, wall forms being setup this week. Tiebacks to be added to both walls for added stability.
    Nice room addition.
    How much for the listening chair in the yard...please include shipping cost
  • verb
    verb Posts: 10,176
    txcoastal1 wrote: »
    Nice room addition.
    Lol that is what I use in the basement!
    treitz3 Posts: 20,123
    I'm a little confused here, Dave.
    Why the big, long ramp for the crawlspace?
    treitz3 wrote: »
    When you get older...your kids can wheel you around and drop you down the ramp for some fun...bowling pins at he bottom??
    audioluvr Posts: 5,990
    treitz3 wrote: »
    Haven't you ever seen Batman? That's where his rocket car launches out of.
  • verb
    verb Posts: 10,176
    edited September 2022
    Good question Tom. The crawlspace is big enough to fit my riding mower, so I needed a ramp to get down there!
    We plan to put a deck in the back there too. The deck portion over the top of the ramp will have hinged segments that flip up to allow access to the crawlspace, but then fold back down when I’m done in there!
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    treitz3 wrote: »
    Yeah!
    It's hard to picture how it will look when it's finished, but it seems like it's all coming together nicely! Thanks for the update.
  • verb
    verb Posts: 10,176
    So some updates. Very slow over the past month. My retaining wall concrete pour was a disaster! The forms failed and they had to stop the pour. Lot's of reasons why, but ultimately the contractor decided to go cheap and hand built the forms, which were insufficient. This held up putting windows and final surface materials (brick, siding).
    A lot of drama, I was WFH and watching it all unfold (no pun intended) in real time!
    In the end, since all the spillage and breaches were below grade, we decided to salvage what concrete that was there and use it as the basis for a block wall footing. All at his expense.
    Finished retaining wall and entrance to crawlspace! Some cleanup yet to do.
    Testing the clearance of the lawn tractor! I am able to drive it in (yeah I have to lean way over, but it's driveable)
    Now all my lawn stuff has a home out of the garage! Can't do a U-turn, but a 3 point turn inside and drive the tractor out!
    Just curious when you will get around to the “new outhouse at Verb’s” thread…. :#:#:#
    Looking good.
