sub box shape
reone98
reone98 Posts: 2
edited February 2005 in Custom Fabrication
I want to install a sub box in my s-10 truck. It's a standard cab with racing bucket seats. I've designed a box to set behind my bucket seats. The drawing i've made look like the following description. It has a triangle shape, with the sub mounted in the bottom left corner (as seen from the front). The sub will be between the seats. I have the correct inside demensions as far as cubic feet. Will this sound ok with the sub offset like this?
Post edited by reone98 on
  • neomagus00
    neomagus00 Posts: 3,899
    it doesn't particularly matter what shape the sub box is, as long as the longest interior dimension is shorter than two feet (longer than that and you could have standing wave problems). the only problem i forsee is that of sq - many trucks have 'sweet spots' and 'dead spots' for subs, even more so than cars, and thus sub placement is crucial to the listening experience. maybe you should build a properly-sized cube and make sure the spot you've chosen will actually sound good?
  • MacLeod
    MacLeod Posts: 14,358
    Agreed.
    The shape of the box wont have any affect on SQ. Just make sure it has the proper interior volume.
  • reone98
    reone98 Posts: 2
    Thanks for the help.
