MIT Terminator 2 Speaker Cables
Getting rid of an amplifier so no longer need these
These are a pair of 8ft cables with spades on one end and regular connectors on the other.
These have been great
$200 plus shipping or local
Pick up outside of Chicago works
  • Dabutcher
    Dabutcher Posts: 2,606
    Love mine. Lot a bang for the buck. GLWYS. D
    heiney9 Posts: 25,492
    Any condition issues? It's hard to see in the photos. Where are you located? I am doing some measuring right now. How flexible are they? It's been a very long time since I've seem a pair in person. I want to use them in my secondary rig, but 8' might be too short unless they are a bit flexible.
    Also what end are the network boxes on, spade or banana? How long is the pig tail? Meaning from the end of the network box to the connectors?
    Sorry for all the questions, but these need to work in a specific space and I need to make sure.
  • teamjhertz
    teamjhertz Posts: 363
    You can interchange the ends length is right around 8 ft overall
    It is roughly 24.5” from the end of the network box to the y of the connector
    Hope that helps
    They are fairly stiff much more than normal speaker cable but still flexible
    No issues with the condition
    pitdogg2 Posts: 27,247
    Drive over and get them Brock. They are on the auction site as well.
    No pressure man 🤣
  • dagame27
    dagame27 Posts: 599
    These are great cables...and way better looking than the old ones...tough to beat at this price.
    ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
    gudnoyez Posts: 8,174
    If only I needed these, great price for some decent speaker cables.
  • teamjhertz
    edited July 2022
    I have another identical set still in use so I have been very pleased with them driving my Lsim705’s driven by an Acurus amp
    Just breaking down my theater set up due to low use
