New to the forum need help with my polk psw 505
i need a BASH amp plate working or not thanks my board got fried a bug crawled between plate and board and fried it wallsicbdpdn.jpg
Answers
  • she was strong until she caught the bug :'(
    F1nut Posts: 51,924
    I don't see how a cucaracha caused that damage.
  • ya crazy still cracthing my head
    F1nut Posts: 51,924
    I used to repair some electronic equipment with a lot of similarities to audio gear. From time to time they came in absolutely infested with those nasty things. Not once did they cause anything close to the damage you have.
    Your sub amp, like many others, is known for cooking itself. The roach just happened to be in the wrong place at the wrong time.
    I suggest you look into buying a different sub and definitely call an exterminator.
    Tony M Posts: 11,680
    edited July 2022
    When I bring speakers with port holes into my cottage, they get a blast of "Bengal" bug killer up their pipe hole. :D
    I might even stuff a big rag in the hole afterwards also.
  • It was a water bug not a Roach And i think i still will hang on to it maybe il find a schematic and fix it or buy another amp with a bash amp to use as road map and fix it hopefuly thanks for the input.
    F1nut Posts: 51,924
    FYI, water bugs are one of the two species of cockroaches, they are Oriental roaches.
  • skrol
    skrol Posts: 3,456
    Parts Express has sub plate amps. I resurrected a Polk sub with one and it was a nice upgrade with just a little cutting.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Thank Skrol for the advice Im trying no to replace with any amp, Instead trying to find a schematic or buy another bash amp to use as road map and hopefuly fix it thanks for the input.
  • thanks for the list stan, luck on ur sale
  • Is there anyone that has a polk 505 bash amp plate working or not 4 sale if so let me know ?
    txcoastal1 Posts: 13,518
    That sub brings this song to mind...
    https://youtu.be/g9lkeoxJRxA
  • Yea it did bring a tear to the eye " LOL" Great song by the way. loves' me some Freddy .
