Seeking Advice
Rescued these Focal 705v from a pawn shop, but the vinyl wrap on front left edge of each speaker is peeling back, but not quite enough to get under it with some wood glue.
It also seems like even if it was, the vinyl wrap wouldn’t quite fully cover the MDF.
Any suggestions on how to get these looking good again?
  • daddyjt
    daddyjt Posts: 3,131
    I had a similar situation with my HT surrounds. Great suggestion from Jesse got me fixed up here:
    https://forum.polkaudio.com/discussion/188428/vinyl-veneer-pealing-anyone-have-a-fix
    ― Aleksandr Solzhenitsyn
  • jbreezy5
    jbreezy5 Posts: 1,141
    So I left the speakers in my truck one night intending to do a trade at a resell it place next day; however, I waited longer than intended, and heat in the vehicle pulled the vinyl back further.
    I took a hairdryer to them for the “sleeveless” look. 😄
    Thinking they might look cool if I use dark purple metal flake paint on the sides.
    nooshinjohn Posts: 25,990
    The cabinets look good. What about using a real wood veneer on them, or painting them a very high gloss piano-type finish with automotive paint?
  • jbreezy5
    Those could both be good options. Will have to do some thinking…
    txcoastal1 Posts: 13,519
    The prep for paint on MDF is a project pending paint type and your skill. Fortunately is a relatively small project space. If you like the sound enough to invest a couple hundy's then yes invest.
    My advice if you ever decide to sell. Choose a basic finish.
    treitz3 Posts: 20,085
    Ron, isn't there a cat down in your neck of the woods that does veneer - like, real wood veneer?
    Jim so and so... (I can't pull his name out of my head right now....)
    treitz3 wrote: »
    Shat....been awhile, but not worth the shipping. J's gotta DIY or local
    pitdogg2 Posts: 27,249
    treitz3 wrote: »
    Try the other end........
  • jbreezy5
    For those curious where I got the idea for purple metal flake paint…
    Fun concept, and I get it.
    They are yours for probably cheap ...all about your dime and if you like them.
    edited August 2022
    Leather would be a nice look too. A high end Ferrari shop could do something really cool on those. Do palomino leather on the baffle and Rosso Corso for the cabinets...
  • agfrost
    agfrost Posts: 2,474
    Rather liked this paint job...
    Toolfan66 wrote: »
    Jay
  • jbreezy5
    agfrost wrote: »
    Toolfan66 wrote: »
    They forgot to do the tweeters. Must've been a work in progress.
  • jbreezy5
    Maybe if I get ahold of some Sopras, or above.
  • jbreezy5
    Another thing about the metal flake concept is the metal plate of the tweeter, texture of the midrange cone, and port all seem to kind of have this going on. Seems like this feature on the outer side panels might tie-in nicely with this.
    Think I'm still leaning in the direction of my original idea.
    It sounds like I will have to learn a bit about painting MDF, per @txcoastal1. Skill level zero. :#
  • jbreezy5
  • Emlyn
    Emlyn Posts: 4,813
    agfrost wrote: »
    The artist might have taken the color inspiration from Focal Kanta speakers in the Gaulois Blue color. $15K a pair seems about right.
    audioluvr Posts: 5,983
    agfrost wrote: »
    Toolfan66 wrote: »
    The Jackson Pollard on acid look! Good choice!
