L400 X over
Braddles63
Braddles63 Posts: 191
edited May 2022 in Speakers
Hey Guys and Girls
Just ordered a L400 centre to go with my R700's and was wondering anyone who had one what X Over setting they where running it at? Full range? 40khz? 60khz?
  • BlueFox
    BlueFox Posts: 15,250
    Try each setting in your environment and go with the setting that sounds best.
  • Emlyn
    Emlyn Posts: 4,814
    80 Hz with dual SVS SB2000 subwoofers and a Parasound A32 amp. The other components, and even the size of the room, matter as much as the center speaker. It's all about blending all the components together to produce the best sound in the room.
    The only right answer is what sounds best in the system. 60 Hz may be better for some speakers in some systems. As big as it is the L400 has a -3dB point of 55 Hz which isn't as good as some large bookshelf speakers. It's likely the L400 will sound best with the crossover at 80 Hz.
  • Milito
    Milito Posts: 2,003
    I run my crossover at 80 Hz on my L400 with my L600's.
  • Braddles63
    Thanks guys. My room is rather large but unfortunately square. 19.8 feet square. Will experiment.
    nooshinjohn Posts: 25,993
    Braddles63 wrote: »
    Sounds like a converted garage... mine is 19’6” by 15 feet just to around the dreaded square. I have a 5’ deep closet behind my gear.
  • Braddles63
    A converted garage is exactly what it is.
  • BlueFox
    Braddles63 wrote: »
    LOL. Both before and after.
  • Braddles63
    edited May 2022
    Excuse the mess. :D
    Earliest pic during the transformation.
    And first pic all finished.
  • rooftop59
    rooftop59 Posts: 8,120
    Looks great!
    Game Room 5.1.4:
    Bedroom 2.1
