Just joined
  • Thanks for the interest from everyone.
    The SL-1000 tweeters just lack some detail in sound. The Monitor 10's next to the RTA 12's really seem to outperform them. Although, there seems to be a wider sound stage with the RTA 12's. I really think they should/can sound better.
    I have some old Marantz speakers I picked up from goodwill that I am practicing on, I'm not the best at soldering. I might try to re-cap them if I get brave. Also, I picked up a pair of Monitor 5's off Market place for a decent price. The cabinets have some damage to them. I looked them over quick and failed to notice somebody's attempt at adding their own hand made "aperture tuning holes" in one. My bad, it was a real let down too. I tried the handmade tweeter in the RTA 12's. There wasn't any noticeable difference. The other tweeter appears to be an actual peerless with the hole. I'll try that one next. (I've been a bit busy.)
    I'll post some new pics later today.
    I removed the cobra cables and will probably hook them up at another time.
  • Looking over my last post I should probably clarify some things.
    I have already recapped the Marantz SP-208's (2X's) I would like to try to recap the RTA12's.
    The Monitor 5's
    A closer look at the tweeter in question--
    The other tweeter
    The back
    I did hook the 5's up to the Onkyo and gave them a listen before removing the tweeter, they sounded fine. Very good actually, I have even considered saving them lol.
    I only installed the funkified tweeter in the RTA's. I didn't notice any difference while doing the side by side comparison. I'm going to keep digging, check the other tweet and pull the drivers on the RTA's to see what's in them.
    I am the RTA's look like they have a wood veneer. Does anyone else have an example of a wood veneer on an RTA 12?
    Thanks for the interest.
    And thanks for the compliments on the username. I'm not an electrician :) Just a cautious geek.
  • Gardenstater
    Gardenstater Posts: 4,728
    I have never seen a number like that or like anything engraved on the plastic terminal cup before. Supposedly those holes were burned with a soldering iron tip but I'm not certain if we have Polk employee confirmation on that. I have thought that another way would be to remove the magnet assembly and punch the hole in the dome. Something went wrong........
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 26,922
    Looks like a drivers lic number in case of theft. Many did that back in the day.
    All the RTA 12's I've seen in person had real wood veneer. Many on the older models had wood veneer.
    audioluvr Posts: 5,866
    Those are coordinates.
  • Gardenstater
    It is possible that there is a terrorist cell here in the Polk Forums that just got its encoded instructions by those particular numbers in that particular sequence :#
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Clipdat Posts: 13,078
    It's also possible that @audioluvr is just day drinking again.
    mhardy6647 Posts: 34,913
    edited May 2022
    even better, many folks used their SSNs in lieu of their DL numbers in those far-more-naive times. :#
