Polkaudio R100 & denon x3500h
Hey, The new speakers are on their way to me and I'm not sure I can turn them on with my receiver which seems to work at 8/6 ohms. I did not quite understand from the data of the speakers if they can work or they require 4 ohms..?
  • rooftop59
    rooftop59 Posts: 7,981
    Alon3t3 wrote: »
    Welcome to club Polk! Stick around.
    You can certainly power those speakers with that avr. Will they sound the best they can? No. But assuming you don’t crank it to 100 dbs you should be fine. I would, however, recommend a good sub and crossing them over at 80 hz or so…
    Game Room 5.1.4:
    Bedroom 2.1
